Anyone know the mathmatical forumula for...
Old Sep 30, 2002 | 05:54 PM
NewZ's Avatar
Default Anyone know the mathmatical forumula for...
Does any one know the formula for figuring out a given rpm if you know the rear gearing, over all tire diameter and the transmisison gear at a certain speed?
I don't know how to do it and would like to know.
Like, what rpm will i be turning with 4.10 gears in a six speed car with stock 17 inch SS wheels and tires?
That's a hypethetical question. I want the forumula for how to calculate that kind of info.
Thanks guys,
Alan
<small>[ September 30, 2002, 06:02 PM: Message edited by: NewZ ]</small>
Old Sep 30, 2002 | 06:23 PM
Ragtop 99's Avatar
Default Re: Anyone know the mathmatical forumula for...
http://www.f-body.org/gears/
I can write it out if you need it but this is easier. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Sep 30, 2002 | 06:38 PM
02 SOM WS6's Avatar
Or You can try this one
Les
Old Oct 2, 2002 | 11:28 AM
NewZ's Avatar
Thanks guys but does anyone know the actual formula? I'd like to be able to do it on paper when i need it and not have to rely on the computer to do it for me.
Thanks!
Alan
Old Oct 2, 2002 | 02:39 PM
Gag_Halfront's Avatar
Well, you could do this:
R = [RPM]
T = [transmission gear ratio (eg: 3.4:1 would be 3.4)]
F = [final drive ratio (rear end gear, as in 3.42 or 4.10)]
C = [circumference of rear tire in feet]
Fm = ((R/T)/F) * C [feet per minute]
Mm = Fm/5280 [miles per minute]
Mh = Mm/60 [miles per hour]
So. Mh = ((((R/T)/F)*C)/5280)/60
Am I close? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Oct 2, 2002 | 02:41 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by red ws6 99:
<strong>Bring up either of the webpages, and either right click on the page and select source or select view then source. That will show you the source code for the webpage. You will see the formula in there.
Gary</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Assuming that the page is javascript (ick)
Old Oct 2, 2002 | 03:02 PM
dug's Avatar
dug
Engine Rpm * Tire Diameter/ axle ratio / 336 = speed <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Old Oct 2, 2002 | 03:07 PM
dug's Avatar
dug
The unit for tire diamter is inches. Stock is 25.6 but when I calculate it comes out to be 25.1 according to the drag strip. Not sure if the tire diameter is slightly shorter when loaded. That is the toughest part about calculating vehicle speed, is figuring out the actual diamter of a loaded tire. Slicks are <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> because they seem to grow at high speeds. I have never got a straight answer to how much because they are all different depending upon sidewall height and etc.
Old Oct 3, 2002 | 12:08 AM
red ws6 99's Avatar
Gary
Old Oct 3, 2002 | 12:35 AM
Ragtop 99's Avatar
Pretty cool, Gary.
Old Oct 5, 2002 | 11:11 AM
NewZ's Avatar
Now i'm more confused than i was before i started. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Alan
