View Poll Results: Are you happy with your moser 9 inch?
I am happy with my moser 9 inch.
72.37%
I am not happy its too noisy,broke or poor quality.
27.63%
Voters: 152. You may not vote on this poll
Old 05-26-2007, 09:15 AM
MY99TAWS6's Avatar
Default Are you happy with your moser 9 inch?
Simple poll. Are you happy with your 9 inch moser. and mabye can explain gear ratio and any problems specifically..noise ,breakage.quality.
Old 05-26-2007, 12:19 PM
35th SS's Avatar
yes Im very happy with this rear end.from the start of the install to the end didnt really encounter any problem.as far as noise it had a slight noise.I just finish my other swap on my 35th and its a currie.Ihad a slight problem on the back of the tq.arm touching the tunnel.corrected that and set my pinion angle.all good here.
Old 05-26-2007, 07:37 PM
billybadd's Avatar
love it so far. Install went very well other than my emergency brake needs major adjustment.
Old 05-27-2007, 01:43 AM
Silas2k's Avatar
2 votes saying no, yet no explanation... whats up guys?
Old 05-28-2007, 05:47 PM
myws6istheshiznit's Avatar
i voted no because i broke mine after 1 track day. we installed it broke it in the way moser told us to used the proper oil. the problem was that i took longer than 90 days to install it. so even though they can look at it and see no wear thay still made me pay them for parts to reapair it. and then they couldnt tell me what caused the break. i dont mind paying for broken parts but when i told him it had only one track day on it he pretty much called me a liar. i have about 20-30 people in the western forum that know my car and can vouch for my story. like i said i dont mind spending the money i have way too much of it in my car but stand behind your damn product and you will have very loyal customers. no more moser for me.
Old 05-28-2007, 08:12 PM
lethal93ta's Avatar
Im happy with mine, BUT, I bought the rear/axle kit from them and put everything together myself, I heard of a lot of people having gear noise from not being set up right so I did it myself.
Old 05-28-2007, 08:16 PM
MY99TAWS6's Avatar
Well that sure does sound like service and warranty are pretty much non existent. Wonder how much better strange is though. You would think a rear end would be pretty simple and hard to mess up but of course you can mess up in setting up the gears for sure.
Old 05-28-2007, 09:22 PM
i have 2 strange center sections in 2 other cars very little noise and never had any problems one of the cars makes around 900 horse. knock on wood
Old 05-28-2007, 11:17 PM
02NBMWS6's Avatar
just pulled my brand new center section bc the whine hurt my ears it was so loud and once apart, i found slight chips on the tops of the ring gear teeth. calling moser tommorrow, i'll keep you updated
Old 05-28-2007, 11:50 PM
chicane's Avatar
Your kidding me right !?!! You do read the threads on this forum dont you ?? My god man... they take up the majority of the around threads here.
On the other hand, Lethal93TA brings up a good point. You are better off purchasing the parts and having them built by someone else... or if your up to the task, build it yourself.
All in all... your pile of parts are only as good as the guy that is screwing it together.
Old 05-29-2007, 04:42 PM
1nastyss's Avatar
Happy so far, but then again i havent had a chance to put my clutch in so i can make some passes on it at the track
Old 05-30-2007, 05:56 PM
02NBMWS6's Avatar
talked to Moser, they wouldnt do a damn thing for me. I had to take it to get set up elsewhere.
when they checked the pattern, the coast side was WAY off and the drive side was low also.
I hate Moser.
Old 05-30-2007, 08:52 PM
WS6 GreeN's Avatar
I've had mine for almost a thousand miles now. Been to the track once. Center section was assembled by Driveline Solutions. Very minimal whine at 60 mph but probably should've gone with 4.11s instead of 3.70s. Oh well.
Old 05-30-2007, 11:20 PM
I hate Moser.
so you feel my pain. did he give you the "drag racing is a tough sport" line?
Old 05-30-2007, 11:29 PM
02NBMWS6's Avatar
yes he did, as well as "six speeds are especially harsh on these rears, it really needs a 9in at the least" well NO ****.
My favorite of all though, and what i couldnt believe was when I told him i found metal shavings in the gear oil, he replied "anytime theres metal against metal there are going to be shavings, thats normal and nothing to worry about"
Old 05-31-2007, 07:15 PM
96mikez28's Avatar
the whole center hub being short thing pisses me off
Old 05-31-2007, 07:22 PM
bigsticksupra's Avatar
they know they can get away with shitty customer service because you HAVE TO either go 12 bolt or 9in. in a f-body and its more than likely gonna be from strange (customer service is just as bad if not worst) or moser.
Old 06-01-2007, 03:33 PM
02NBMWS6's Avatar
what do you mean?
Old 06-06-2007, 10:32 PM
HAHA I 1's Avatar
No problems whatsoever. I have had both a 12 bolt and a 9" from them. I even have the dreaded locker and still love it.
Old 06-06-2007, 11:12 PM
juicedls1's Avatar
I,ve had mine for over a year, 33-spline, spool and 4.11 and love it, drive it everywhere, wouldnt own anything else, the rear is as quiet as can be and no leaks!!!
Quick Reply: Are you happy with your moser 9 inch?
