2.73s to 3.42s?
<small>[ November 29, 2002, 01:06 AM: Message edited by: Skinny ]</small>
In my opinion, a good converter with those 2.73s will give you more than the gear swap, but 3.42s would let you run a higher stall converter w/o the "looseness" around town,or maybe just feel a little peppier with the stock converter.
Guess it just depends on what your goal is.
In other words, was it enough to just use the SLP speedo calibrator/Hypertech ratio change/"New Gear Ratio" box in LS1-Edit? Or did you end up hitting the limiter and need to tweak further because of the faster RPM increase and slow shift time?
I already have a Vig2800, by the way, and may get it restalled within the next year, but don't have any immediate TC plans.
Thanks
Mark
<small>[ November 29, 2002, 04:05 PM: Message edited by: squirrels ]</small>
It will definitely feel peppier around town than with the 2.73s, although the 1/4 mile gain would not be much.
If you are determined to change gears, then I would definitely do that before I bought a TC, as the gears will influence which TC you ultimately get. For example my car with 2.73 gearing and a ST3500 TC with it's 2.5 STR is already somewhat traction challenged on street radials.
later'
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Skinny:
<strong>Thanks for the reply guys. The only reason I was interrested in the gear swap is because I already have the gears. Of course there are other things I would be doing before a TC or gear swap, such as some induction and exhaust mods. Since I already have the gears and don't have a bunch of money at the moment to throw at a good TC, but do have a spare $100 for an SLP take-off torsen, I figured the gear swap would be a great "bang for the buck" so to speak. Even if I had to buy an HPP3 or some other form of computer tuning, which I planned on buying anyway, to adjust the shift points and what-not, would it still not be worth the extra $100 for the new carrier when I ALREADY have the gears and can do the swap myself??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
I think I am going to order a Midwest 3200-3500 w/2.5 STR. Pretty cheap and I havent really heard anything negative about them, and they come with a 2 year warranrty.
