Midwest Chassis fabricated 9 inch
Old 10-16-2007, 07:34 PM
  #41
PONYEATER's Avatar
Looks great! Can you do anti roll and wheelie bar mounts? fill and drain plugs?
Old 10-16-2007, 10:21 PM
  #42
LS1Tech Premium Sponsor
ssvert99's Avatar
i can install anything you want. anti-roll, stock sway bar, wheelie bar mounts, etc. i have already done the anti-sway on the chassis car rearend, and all the components are laser cut. no problem to make a few(hundred) more!
fill and drain plugs are standard on all the rearends, though the 4th gen. f-bodys are real close to the fuel tanks if the car is lowered.
i'm gonna have 10 or so housings in stock and most of them will already be powdercoated. should be able to get these out quickly.
Old 10-17-2007, 09:47 AM
  #43
00ultraz28's Avatar
will you sell just the t/a adapter? Can you post up a pic of that after it comes out of cnc
Old 10-17-2007, 11:10 PM
  #44
ssvert99's Avatar
mmmm.... probably not. I have alot of time and money invested in getting this stuff rolling. the quantitys being built are the same as the rearends being prepped for them.
Old 10-17-2007, 11:24 PM
  #45
lilicedout24's Avatar
im in can u build me 1 with 430's or what u think would be best for my set up u can PM me price and specs
Old 10-18-2007, 01:41 AM
  #46
Transamman25's Avatar
PM me a price bolt in 3ch and 4ch
Old 10-18-2007, 05:30 AM
  #47
Black FormulaLs1's Avatar
PM me a price for one complete with detroit true trac diff 4:10 gears and forged axles shipped to 31301...please?
Old 10-18-2007, 09:16 AM
  #48
ssvert99's Avatar
pm's sent... priced as a complete rearend and torque arm setup w/ crossmember and driveshaft loop. housing-t/a package and housing,t/a,axle packages available too.
Old 10-22-2007, 11:43 AM
  #49
2fast02TA's Avatar
I just got mine for my TA. Got 31 spline axles, 4.10 gears and a detroit True trac posse. This thing is badass. All powercoated black. Also got his suspension setup that is top of the line as well.
Thanks Eric
Cant wait to take it to the track and see how hard i can launch this thing.
Old 10-22-2007, 11:49 AM
  #50
217zenki's Avatar
pm sent.. Has anyone been to the track yet on this setup?
Old 10-22-2007, 12:12 PM
  #51
slowcamaro's Avatar
an i get a price on one with NO abs or traction control
Old 10-22-2007, 08:28 PM
  #52
10SecDreamer's Avatar
Thanks Eric
Can I get a quote like this one too but with 3.90 gears? Need a 9" here pretty soon I sorta got addicted to the track now.
Old 10-23-2007, 12:42 PM
  #53
hazard2k's Avatar
Price on complete unit – 4.30 gears – truetrac – 4ch abs
Could I get a price on both with your torque arm setup and also one with the bracket to use my existing one.
Old 10-23-2007, 03:16 PM
  #54
HSESWS6's Avatar
Eric makes a sweet rear end, I have watched him make several and even installed a few. This winter if cash flow is right I will be putting one in my TA
His personal car with his complete suspension setup and rearend went to the track Sunday for some passes to dial in the new motor combination. I'm sure he can chime in on how it went / what he launched at.
Looked good from where I was standing
Old 10-27-2007, 02:57 PM
  #55
ssvert99's Avatar
these rearends include the torque arm and crossmember as part of the standard package. tunnel mounted, or trans xmember available, depending on your setup requirements. the torque arm is monted to the crossmembers with an adjustable link, which uses a Energy Suspension poly bushing at the crossmember and a teflon lined Aurora heim joint in the arm. this setup is incredibly quiet, compared to the to the soild type ones others offer. non-bushed links also available for all out race applications. more pics coming soon!
Old 10-27-2007, 03:23 PM
  #56
SSwanner's Avatar
it was nice talking to you the other day man. just one quick question, can you powdercoat in red?
Old 10-27-2007, 05:10 PM
  #57
qwikz28's Avatar
next assembled one you have, can you weigh it for me?
Old 10-28-2007, 10:54 PM
  #58
mavedawg04's Avatar
Pm me prices on one for stock torque arm and 31 spline axles with the 4 channel. I just need the housing and axles making my own setup. oh and you outta check out the 4 link caprio motorsports does. I'm goin that way.
Old 10-28-2007, 11:45 PM
  #59
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Ok, I was checking out your site and rereading this thread again.
I noticed the specific TA for this setup is rather short. I noticed most of the other sponsors use a longer design. What thoughts went into place when designing that?
What are the weight differences between the steel and chromemoly housings? After reading it seems like the center area is chromemoly and the axle tubes are stainless?
Sending PM on pricing.
Old 10-29-2007, 12:59 PM
  #60
ssvert99's Avatar
the t/a in the pics is a tunnel mounted type. i offer trans crossmember mounted ones, also, at the same price. the difference in the two is exhaust options, and power levels. the higher powered cars will benefit from the longer arm, footbrake or lower power cars will make better use of the tunnel mounted type.
the housing is offered in complete mild steel, or complete chromemoly. there isn't much difference in the two for weight, but the chromemoly is much stronger. all of the suspension components, including the torque arm are made from 4130 chromemoly.
Quick Reply: Midwest Chassis fabricated 9 inch
