373 1/4 mile
Internet Mechanic
http://www.f-body.org/gears/ (for calculator)
I did a quick calculation based on a 6k redline, 245/50-16 or 26" tall tire, in 3rd gear you should hit redline @ 123mph. So basically a wicked h/c set up, or a good shot of juice on a cam only set up would I worry about hitting it. Worse comes to worse, you short shift so you come in lower in the next gear, this saves taggin the limiter at the end of the track
http://www.thunderracing.com for gears and kit.
I noticed a difference as soon as a started out in 1st gear when I finally got it back from the mechanic. I was worried about hitting the rev limiter in the 1/4 with 4.10s, thats why I went with the 3.90s.
