Moser 12 = Blowed up = Bummer = Pics
Old 12-14-2007, 09:32 PM
TA1364's Avatar
It was the flames that caused it to break
Old 12-14-2007, 09:40 PM
97slowbra's Avatar
to bad to see that happened to you. i exploded my carrier car in my stock 8.8. it has been sittin about two months on stands also. that is an awesome price jeff quoted you for. and 33 splines are awesome a friend of mine just did a swap in his f body and he puts down alot of power. holds great.
Old 12-14-2007, 10:06 PM
TAEnvy's Avatar
You broke a moser 12 bolt, on a Bald Kuhmo Ecsta 712 and 330-340whp. WOW!!!
I will not be buying a 12 bolt. I dont care what it was that broke, thats sad.
Old 12-14-2007, 10:40 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
How long did you have that rear in there? It seems odd for it to let loose on street tires.
Old 12-14-2007, 11:05 PM
fastlane02's Avatar
very odd.
Old 12-14-2007, 11:58 PM
1BADAIR's Avatar
Originally Posted by Jawsgear
Looks like stock 30 spline internals on that Eaton. If you upgrade to the 33 spline you get a much stronger material and it is the old school cut gears instead of the cast gears like Eaton uses. Also, get rid of those carbon clutches and go with the 18 pack steels. You get a little chatter around corners but they will hook way better.
Jeff
It was a 33 spline. It now has a spool, but after 3 runs is already leaking and noisey.
Time for a 9 inch cause this is the 3rd time I have broke it
Old 12-15-2007, 01:11 AM
ae13291's Avatar
was this caused by a bad pinion seal??? i dont see how this wold break so easy!!
Old 12-17-2007, 10:33 AM
Posi12Bolt's Avatar
Originally Posted by BlackScreaminMachine
I hope you get it together soon.
got the rearend back together, just gotta put it back in the car now...
Originally Posted by SuperSlow02
was that a 10 bolt?
ahh...no
Originally Posted by 1BADAIR
a few broken pieces from when my moser 12 bolts broke
great carnage!
you know they give me 50 rwhp!!
Originally Posted by 97slowbra
to bad to see that happened to you. i exploded my carrier car in my stock 8.8. it has been sittin about two months on stands also. and 33 splines are awesome a friend of mine just did a swap in his f body and he puts down alot of power. holds great.
I have 33 splines!
WERD!
13k miles... built in 2004
i was on the highway doin 87 mph on cruise...
Originally Posted by fastlane02
very odd.
i dunno...
you know how many people have asked if I ran it low on fluid?
it didnt start leakin till it went kaboom!
Old 12-18-2007, 11:29 AM
LS1crazy01's Avatar
Sounds like you would have been better sticking with the 10 bolt lol at least its cheaper to replace LOL! I think im gonna go with a 9inch after reading this one.
Old 12-18-2007, 05:36 PM
SuperSlow02's Avatar
ahh...no
sure did break like one, read your title and everything..but after description..made me think of a 10 bolt haha
Old 01-03-2008, 11:43 AM
Posi12Bolt's Avatar
Carnage pics... as removed from the rearend!
Old 01-03-2008, 11:57 AM
  #32
Jordan S.'s Avatar
Moser packages some cheap **** with their rear ends sometimes. One of the wheel bearings split when the shop pressed it on. The studs are junk. I wouldnt run the stock moser studs for five miles. Mine all snapped off after about 120 highway miles. The same happened to another guy around here on his 12 bolt. We both have ARP's now, no problems.
1BadAir, that looks like your posi stuff. You cant blame the 12 bolt for that, blame the differential.
Old 01-03-2008, 12:32 PM
  #33
Jon5212's Avatar
He said he had 33 spline axles and diff... that is crazy for that level of power to blow up a 12 bolt. Wow first i've seen.
Old 01-03-2008, 04:03 PM
  #34
Cam Can's Avatar
I can't speak on whether Moser has good stuff or not, but I do know that I've seen some stout engines backed up by 12-bolt rears - and they lived! It could have to do with whether or not it was properly set up, poor quality parts or a combination. Who knows? But I'm with you in not blaming the 12-bolt. To me, the weak point in the 12-bolt is the C-clips. Yeah, there are C-clip eliminator kits, but...
Old 01-03-2008, 04:23 PM
  #35
1BADAIR's Avatar
mine doesn't have c-clips.
Is that the pinion bearing? I broke one too before I put the solid spacer in. I crushed the crush sleeve launching the car once and broke the pinion bearing. Even with the solid spacer the gear pattern and backlash moves after a few launches
Old 01-03-2008, 04:54 PM
  #36
redramair98's Avatar
I had about 5,000 miles on mine, and all i had was head and cam car, and after about the first few hundred miles it started whineing and got louder and louder as time went on
Old 01-03-2008, 06:32 PM
  #37
Posi12Bolt's Avatar
yeah thats the pinion...
I don't have c-clips either
Old 01-03-2008, 07:54 PM
  #38
Cam Can's Avatar
So I take it that you guys have the C-clip eliminators. I've "heard" mixed reviews on 'em. Weren't they supposed to be for the track and not for use on the street. At least that's what I had understood at one time.
Old 01-03-2008, 08:29 PM
  #39
Jake@EPP's Avatar
Is your vehicle a 6spd car?
The 6spd cars have a HUGE issue with the 12bolt, we only reccomend 12bolts for autos, and even then its not really much more to get a kick *** 9" setup.
The issue with the 6spds is the shock from the clutch dump will cause housing flex via tq arm. Seen it time and time again, starts out quiet as can be, then noisy. They normally do not fail, just become loud.
Old 01-03-2008, 08:49 PM
  #40
EPP
EPP's Avatar
Thumbs up
COMPLETE MOSER 12 BOLT
Moser Engineering offers the best aftermarket 12 Bolt on the market. Our 12 Bolt housings are newly cast nodular iron housing units that are direct replacements for most leaf-spring, coil-spring, and torque arm General Motors OEM applications. The extremely durable housing units have giant caps utilizing half inch Allen bolts, and include perches or brackets. You have a choice of axles with pressed on ball bearings, or OEM style c-clip with c-clip retention. The units can be set up for anti-lock brakes and work with many OEM GM brake setups. Utilizing new housing ends adds to the simplicity and ease of installation, which is unparalleled in the industry. The complete package includes a Moser 12 Bolt housing, Custom Alloy Axles with ball bearings, studs and retainer plates. Also includes either a Moser full spool or a posi unit, Pro Street gears, 1350 series pinion yoke, chrome cover, and assembly. Brakes are not included. When ordering with a Moser full spool or a posi unit, you have the option of 30 spline axles or upgrade to our 33 spline axles, which carry a 10 year replacement warranty. However, if you are ordering the package with c-clip axles you can only order 30 spline axles. TWO-DAY TURNAROUND ON ALL ORDERS!
This is from Mosers website, and the only ones I sell do not use c clips. Bob
Quick Reply: Moser 12 = Blowed up = Bummer = Pics
