Moser 12 = Blowed up = Bummer = Pics
Old 10-08-2007, 08:51 PM
Posi12Bolt's Avatar
Default Moser 12 = Blowed up = Bummer = Pics
this morning around 5:30am I was on my way home from work, I go through the Benicia bridge tolls make make a hard 1st - 2nd holeshot up into 3rd then just cruised.
I get up over the bridge, shift into 6th set the cruise at 87 and go for a few miles... outta nowhere... it clunks and then feels like I put the brakes on... BUT I DIDNT...
now i hear metal to metal and it feels like hell, loose and clunky...
I slow to around 25 mph and go another 1/4 mile up the road to the offramp to get off the highway in the middle of nowhere...
in the one pic you can see the gear oil pouring out of the pinion seal like a hose this leads me to believe the pinion bearing took a ****. I still goes forward farely easy but reverse feels like your tryin to drive on sqare rims...
no point to the thread just bummed, I was having fun drivin the T/A everyday... guess its time to point the ten bolt back in a sell it...lol
~Brian
UPDATE: Carnage pics
Old 10-08-2007, 08:58 PM
brad8266's Avatar
You can pull it apart yourself, its really not hard to do. Thats too bad that happened, it sucks when **** breaks. Hopefully its just the bearing which is pretty simple to fix. Takes about 15 minutes to get to the bearing to see if its busted.
Old 10-08-2007, 09:05 PM
Posi12Bolt's Avatar
well thats hopefully all it is, i just hope all the teeth are intact...
its sounds pretty nasty when you move it
Old 10-08-2007, 11:12 PM
chrismorales75's Avatar
Shoulda bought an S60 =)
Old 10-09-2007, 12:48 AM
Posi12Bolt's Avatar
is that like a Dana or something?
Old 10-09-2007, 12:54 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
yeah its a Dana 60
Old 10-09-2007, 01:09 AM
Posi12Bolt's Avatar
Originally Posted by Ryne @ CMS
yeah its a Dana 60
thats a bit overkill bein as this thing only has MAYBE 330-340 rwhp...lol
not that I wouldnt mind havin one
Old 12-13-2007, 12:02 AM
Posi12Bolt's Avatar
she hasn't moved in 2 months... I hate not having enough time in the day!
now where is the best place the get the pinion bearings I need? inner and outter and seal
Old 12-13-2007, 12:54 AM
Jawsgear's Avatar
Here of course..... hahahaha
Old 12-13-2007, 05:49 AM
Posi12Bolt's Avatar
I asked for a price request on the NorCal forum... you probably haven't seen it yet
Old 12-13-2007, 07:25 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I hope you get it together soon.
Old 12-13-2007, 11:17 AM
Jawsgear's Avatar
hmmm, I have not seen your post. $82.00 for a Master Timken Kit though. Let me know if you need one I have them in stock.
Jeff
Old 12-13-2007, 04:24 PM
SuperSlow02's Avatar
was that a 10 bolt?
Old 12-13-2007, 04:59 PM
LS1powerhouse02's Avatar
Originally Posted by SuperSlow02
was that a 10 bolt?
huh? Re-read the title and then look at the picture he took from the rear of the differential. How many bolts do you see?
Brent
Old 12-13-2007, 07:42 PM
Posi12Bolt's Avatar
Jeff
whats that consist of?
Old 12-13-2007, 08:11 PM
Brent
sadly enough...I missed the title..even though i read it, idk how to count the bolts...I dont have any on the back of my rear
Old 12-13-2007, 09:53 PM
Jawsgear's Avatar
Master Timken Kit Includes: Pinion Bearing & Races, Carrier Bearings & Races, Pinion Seal, Crush Sleeve, Pinion Shims, Carrier Shims, Pinion Nut, Ring Gear Bolts, Gear Marking Compound, Loctite, Brush, and Gasket/Sealant.
Jeff
Old 12-14-2007, 06:02 PM
1BADAIR's Avatar
a few broken pieces from when my moser 12 bolts broke
Old 12-14-2007, 06:30 PM
Jawsgear's Avatar
Looks like stock 30 spline internals on that Eaton. If you upgrade to the 33 spline you get a much stronger material and it is the old school cut gears instead of the cast gears like Eaton uses. Also, get rid of those carbon clutches and go with the 18 pack steels. You get a little chatter around corners but they will hook way better.
Jeff
Old 12-14-2007, 06:35 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
was that a 10 bolt?
..YES....YES IT WAS..........
Quick Reply: Moser 12 = Blowed up = Bummer = Pics
