6.xx/7.xx gear ratio
LS1Tech Sponsor
Short track or dirt track racers use them to stay up in the rpm's in and out of the turns. I actually built 3 Ford 9 inch center sections a few months ago for a race team. One was a 6.00 with a spool, 6.20 with a spool, and the last one was a 6.50 with a spool. They are really hard to set up just right to handle the power and heat. The teeth cut on a 6.00 ratio is 36 on the ring and 6 on the pinion.
