SS4200 vs. PT4400
Old Jan 4, 2003 | 01:27 AM
quickWS6's Avatar
Default SS4200 vs. PT4400
Which is quicker at the track? Which is better from a roll? And, how much of a difference?
Also, what STR is most people using on the TP4400? Everywhere I've seen it says it ranges from 2.2 to 2.7.
Old Jan 4, 2003 | 09:59 AM
Patrick G's Avatar
LS1 Tech Administrator
Default Re: SS4200 vs. PT4400
Nobody's run a SS4200 yet so the comparison would just be bench racing. I would expect a SS4200 to have a harder 60' time, but less mph in the traps and less shift extension vs. the awesome Pro Thruster 4400.
From a dead stop, ie 1/4 mile: Even
From a roll: PT4400 by a nice margin
The stall torque ratios for the Pro Thruster converters vary according to stall speed. The lower the stall, the lower the STR. A PT4000 will have a STR around 2.2 and a PT4600 will be closer to 2.7. The PT4400 is around 2.5.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 5, 2003 | 11:23 AM
OBSSSD's Avatar
I'm a little confused Patrick. I just got a PT4000 in and will be installing soon. Yank's website says the PT4000 is a 2.3 STR but I was told the converter I have is 2.86. I will be spraying anywhere from 75-125 wet shot of TNT and would prefer to have the 2.3 so I can spray sooner out of the hole.
What are your thoughts?
Old Jan 5, 2003 | 07:13 PM
Patrick G's Avatar
The STR is not as high as 2.86. If it was, it would feel a lot tighter than it is. The PT4000 is a loose feeling converter with a lower STR than you were told. That's a good thing and it should rock for you on a small to medium size nitrous shot. Go for it.
Patrick
__________________
Old Jan 5, 2003 | 11:22 PM
OBSSSD's Avatar
How big of a shot will the PT4000 handle with my TR224-112 cam with 6600-6700 shift points? Will 75-125 be fine?
Old Jan 6, 2003 | 01:08 AM
Colonel's Avatar
It will physically take alot of N2O. The problem is it will stall higher than what would be best when running N2O. Your shift extension will be too high.
I used to run a 125 shot on a TP4600. It worked but I felt it was costing me at least 3 tenths as compared to running a tighter converter. The more N2O you run, the farther away from optimal you get with a too loose converter.
Old Jan 6, 2003 | 10:07 AM
OBSSSD@work's Avatar
Would shortshifting the car with a spare N20 pcm be of any benefit wen using a 125 shot with this converter?
Old Jan 6, 2003 | 10:28 AM
JC's Avatar
JC
I just ordered a YPT4200 and I was told it will be a 2.86STR. That had better be correct! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Old Jan 7, 2003 | 12:01 AM
Colonel's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by OBSSSD@work:
<strong> Would shortshifting the car with a spare N20 pcm be of any benefit wen using a 125 shot with this converter? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, you'de be better to shift it a little low. With a NA shift point of 6200 I'd try shifting at 5500-5700 on the juice with that converter, for example.
