rear differential is hot
He said the rear didn't smell right. I got down there and felt it, and it was so hot I could barely touch it. The car smelt like a car that's been driven hard for a little while, I didn't know what he was getting at.
I just had 4.11 gears installed less than 1000 miles ago. I know the rear isn't leaking fluid, but I guess I'll check it anyways. There's obviously a lot of friction in the rear, but should it make the differential that hot?
And yes it will get that hot. Ever tried touching your block after a drive? I did and I got a nice bubble on my finger. After that I don't touch any mechanical components on my car for a good few hours.
My friend just installed a oil cooler for his Z06 rear end and M6 tranny. Its a pump that pushes the fluid through two coolers. Pretty cool I thought.
You can buy a pump from Tilton that will handle hot gear oil or trans oil. They are $199 from truchoice performance (www.truchoice.com) and you will need:
1. Pump
2. Braided line (#8 or #10 AN line)
3. Fittings for the rear (if you use a TA performance rear cover, pull it from the drian hole and return it to the fill hole on the cover. You'll need the correct pipe thread fittings to fit the cover (pipe thread to AN adaptors).
4. Cooler (something with large oil passages and several passes or a mocal or similar professional oil cooler)
5. Fittings to adapt your an line to the cooler (if the cooler has pipe thread fittings, you'll need more fittings like the rear cover uses, if it is AN (likely #6, #8 or #10), I'd use the same size hose and fittings for the whole thing).
6. Extra fluid (to fill the pump and lines and keep the rear full.
7. A power feed, fuse and power relay to wire up the pump to the cars electrical system.
That's the basics.
Kevin
