2 Series or 3 Series (Pic Included)
Hey guys is there anyway that any of you can identify whether I have a e 3 series or 2 series carrier from this pic? I keep hearing about the thick and thin ring gear but don't have an example of both to compare with.
Thanks,
Josh
Thanks,
Josh
![](http://i56.photobucket.com/albums/g188/connexion2005/T56%20Rebuild/HPIM1712.jpg)
They are GM AAM Motive Gears 4.10 Ratio Set...I havent checked for numbers on the posi yet. Are there numbers on it? It's obviously the auburn unit though...
hey I can't see the picture but to tell a 2 series and 3 series carrier apart is fairly simple. The reluctor ring on a 2 series carrier is about 1/2" thick, muuuch thicker then the 3 series which is only about 1/4" thick
Well the thing is man I don't have the large reluctor on the carrier. I have TCS so I have the two small reluctors on each axle shaft. Any other way to tell?
I did the same thing as sdimess did, ordered 3 series gears and had a 2 series carrier, now the gears are still sittin in the closet after a year. anyways yeah sorry I gave you information that doesn't even pertain to your situation. again I couldn't see the pick but I tried lol.
Those apply to all applicable GM 7.5/7.625 Auburn,Torsen,and Eaton carriers as pinion centerline vs. ring gear mounting surface distance must be maintained irrelative of what type of LSD is used.
Now those dimensions will vary(only by thousands of an inch)because of manufacturing tolerances.Those two were the first of my many carriers I grabbed to photo.My others carriers might not have those exact dimensions and variances in rearend assembly in accomodated with the use of the carrier shims to set lash.
