Will my 10 bolt hold on?
Don't waste money on the axles. What are you going to say when your axles don't break, but your carrier lets loose instead? That is the problem with the 10 bolt. It's a vicious never ending cycle of replacing parts. Do the 4.10s if you want to, put the axle money in a piggy bank labeled "9 inch fund" and don't count on it holding together in the meantime while you flog it at the track.
I'm still on the stock 10bolt myself w/4.10 gearing and every pass knocking on wood. Good luck.
