Quaife differential
Old Jul 26, 2008 | 09:34 AM
Mr.427's Avatar
Question Quaife differential
Anyone familiar with the new Quaife differential. Looking into this through RPM and would be interested to hear your experience.
Old Jul 26, 2008 | 02:01 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Those are very expensive and are popular with the imports. A Torsen or Truetrac would be my next choice if you are looking for a worm gear style differential.
Old Jul 26, 2008 | 03:01 PM
sportfan's Avatar
X2 ... very expensive, but they are very nice units!!
Old Jul 26, 2008 | 07:15 PM
Mr.427's Avatar
Scott all I know is there are no clutches or springs just gears. So yes I would expect there are worm gears involved.
Old Jul 27, 2008 | 11:59 AM
LS1Tech Sponsor
The Truetrac or Torsen are the same design as a Quaife and I have no knowledge if one is stronger that the next. I guess it all depends on your budget, Average Truetrac is $450.00 and Last I heard a new Torsen is around $750.00.
Old Jul 30, 2008 | 05:12 PM
stevieturbo's Avatar
Quaife make very nice diffs, and usually have steel billet carriers. I think a lot of them come with a lifetime warranty too, although no doubt there are catches.
That said....Im using a Ford Racing Torsen in my 8.8"....so far its great, and cheap IMO.
I wouldnt even consider a locker or plated type diff.
Old Jul 30, 2008 | 08:12 PM
Jake@EPP's Avatar
The quaife's are huge in the import market for a reason, they work! They are not cheap, but they are one of the best diffs for street driving.
Old Aug 2, 2008 | 07:08 AM
speedracer5532's Avatar
I just broke my tru-trac and was wondering if the Quaife would be any stronger than a tru-trac. I will not consider a locker or spool in a street car.
Old Aug 2, 2008 | 07:46 AM
When the tru-trac breaks...what gives ?
In any of the pics Ive seen, I think its usually the cheap cast carrier that fails ??
I would have no hesitation in thinking a Quaife would be stronger than any typical cheap US diff, or a plated style diff that retains a diff pin.
A friend broke his Unitrax Viper diff last year, and he's switching to a Quaife for his rebuild. Its circa 900rwhp......he might even go faster than me some day
If I couldnt have got my 8.8" Ford Torsen so cheap, I would have bought a Quaife.
As with you John....absolutely no way in hell will I ever have a spool in my car again, and the thought of a locker doesnt have much more appeal.
The spool was only a temporary measure anyway, but I never thought they would be so bad..
Add to that, it didnt improve my 60fts or traction one bit.
Old Aug 2, 2008 | 08:05 AM
On mine I broke teeth off of the center gear. I knew all along my tru-trac was a weak link in my 9 inch but as stated I didn't want any of the other options.
Old Aug 3, 2008 | 04:06 PM
Do Ford Racing make a Torsen for the 9" too ??
I think the one in my 8.8" is great.
just took the rear end apart to swap gears, and both diff, and new Mark Williams shafts look fine
Im very pleased to see that !!!!! The Moser shafts had a habit of twisting
Old Aug 3, 2008 | 04:10 PM
bigsticksupra's Avatar
the quaife is a really nice diff. you can't even compare a true trac to a quaife. very very high quality and i believe it has a lifetime warranty even when you're racing it. you broke the trutrac with 940rwhp? dam that's still pretty good...im surprised you're not twisting the splines on your 31 spline axles.
Old Aug 3, 2008 | 04:16 PM
NJSPDER's Avatar
Quaife is known for their racing support and standing behind their product. They are expensive, so it really depends on how bad you plan to beat on it. If you are out on road courses and getting after it on the regular, you will benefit from the extra support.
If you plan on just drag racing/street driving the car, I doubt you will get any benefit from the extra expense.
Old Aug 3, 2008 | 04:21 PM
The benefit from the extra expense, is a stronger diff, that is less likely to break.
Whats the point in buying cheap diffs, if they break all the time !!!
Old Aug 3, 2008 | 04:54 PM
I knew when I put my 9 inch in with a tru-trac my differential was going to be my weak link in my rear but it lasted almost 2 years with 900+ hp in a 4000 lb car so I am not complaining about my tru-trac. I will definitely stay with a differential but will consider going with a Quaife if it will be stronger and possibly not break on me.
Old Aug 3, 2008 | 06:06 PM
Quaife ATB Differential Limited Lifetime Warranty
Autotech Torque Biasing Differential Lifetime Warranty: Autotech warrants each new Quaife ATB Differential against defects in manufacture, material, workmanship, and wear-out when used in the vehicle application for which it was originally designed, on any motor vehicle, under any and all operating conditions, including racing, for as long as the original purchaser, or any subsequent purchaser owns the differential. The original purchaser must complete and mail in the accompanying warranty registration form within 30 days of the purchase date to qualify for this warranty. The registrant must present a copy of this warranty together with a copy of the original receipt to the service outlet or parts store from whom the differential was originally purchased when making a claim for replacement or repair. All warranty claims submitted must include proof of purchase. Failure to provide proper documentation renders warranty null and void.
Old Oct 21, 2008 | 06:39 PM
YO-EL's Avatar
No clutch packs to wear out..
Anyone use them drag racing in a C5?
Old Jun 10, 2009 | 03:29 PM
YO-EL's Avatar
Got one & selling it..
Too expensive to be sitting since its now my spare!
$3000
Will also include brand new GM Getrag Z06 shot peened 3:42 ring/pinion in case you prefer 3:42's to the 3:90's! And an extra 300M hardened passanger side shaft!
