9" vs fab 9"
It's like comparing hand-ported heads to CNC ported heads. CNC ported heads are always going to look better and the port shape will be exactly the same every time. However, it doesn't mean diddly squat unless it's a good design with a port shape that flows well.
So here's my opinion. While the welds on the M9 may look slightly better (again due to being welded by a ROBOT), the design just doesn't appear as good as the Midwest Fab 9.
So here's my opinion. While the welds on the M9 may look slightly better (again due to being welded by a ROBOT), the design just isn't as good as the Midwest Fab 9.
all of my housings are full welded, inside and out... every seam, every joint. these standard housings use both MIG and TIG welding process. Moser's sheetmetal is welded on the outside only, and then ground smooth. they use a single piece, fold it together, then weld the corner seams. i use a 3 part design that has the outer sides and center piece all folded and weld them together. i MIG weld the inside seams and TIG weld the outside. they are both good designs and are plenty strong. its simply a difference in the manufacturing process. while Moser currently does not use robots, they do use rotary machines... hence a smooth weld all the way around a tube.
yes, the quality of the Moser welds are great... as i would expect them to be. Moser makes great quality components... as i would expect them to. this is Moser's main business and their products need to be of the highest quality and looks to stay well established in the market.
I build everything from complete turn key 200 mph top sportsman cars to 10 inch tire NMCA/NMRA street type cars, headers, suspension components, etc. these bolt-in rearend housings are just another part of the mix. the focus is on the typical guy that needs a street friendly, racecar type rearend thats affordable, performs, looks good, and is easy to install.
crazylane... another comment here like the one and you will have problems...i suggest you peacefully bow out now.
C'mon man, you know what I spent because I posted it earlier in this thread.
31 spline axles
3 channel ABS
3.89 gears
Black powdercoat
Built-in anti-sway bar brackets
Built-in LCA relocation brackets
Iron center section
TrueTrac differential
Fill/drain plugs
Chromemoly transmission crossmember
Chromemoly torque arm
Moser/EPP price: $3600 shipped
Midwest Chassis price: $2975 installed
Also, what I got actually cost $2775 in parts because I paid $200 for the install. I would've paid $3600 for the same parts in the M9.
By the way, where are you stationed on Whidbey? I was stationed at NOPF for 6 1/2 years and I'm trying to go back.
Somebody lock this pathetic thread already
How does me being military have anything to do with this thread??? I am going to tell it how I see it.. again, thats my .02..
I mentioned way back in this thread that I had nothing bad to say about your stuff.. Now did I??? And I also said I would not say anything, due to not seeing your stuff first hand..
Both of these rearends are nice. No doubt about it. People that were sticking up for you, were pretty much saying that they though the M9 was ****. Thats when the **** started to get tossed at each other.
If you wanna go cry to a mod, then by all means go do so. I am still going to stand by what I think, and if you can't swallow what I said, then thats pretty sad..
I do have a question though..
Why do this??? Why not trust your employee's to do this. I mean if you are taking this into your own hands, just to prove a point, then that means you will be taking special measures to try and show that your product is far superior..
My main point is, use one of your everyday builds.. Don't go and build something just for this.. Cause more than likely the rear end will not be on the same level as the rear's you sell to everyone else..
We don't have the same parts though, so it's hard to actually compare. For example, you have a spool and I use a TrueTrac; which if you go on EPP's site, is a $300 difference in the cost of a center section (nodular center w/spool = $975, nodular center w/TrueTrac = $1275).
Sorry I over looked this..
I am stationed at VQ-2 Squadron. I am there safety guy. Not very fun. I haven't touched a machine in about 14months.. I am starting to have my withdrawl's ha ha.
Actually I just put in my 1306 to do a split tour, and get back to the real navy.. (SHIP)..
Also, I do have to agree, the airdale community is definitely the "gravy navy". It's definitely not the "real navy" for sure. I love Whidbey Is. though (it helps that I'm actually from WA.).
COMMENT EDITED OUT BY REQUEST...... ****. We know you like his FAB9 allready. Both of these rears, are the best bet for any hardcore car guy... Thats all that counts. Both of these rears will hold up to more power than 99.999999% of us will EVER have..
So with that said lets get on a new topic already..
You're an idiot... After making that comment...
Guess how much HP he has...
http://www.youtube.com/watch?v=YCsdSe0G4LQ
Tobad I can't open up youtube right now. so somebody feel me in on what this video is please...
