Taking apart 10 bolt
Can anyone help me out?
Thanks for the help
If you have ABS, which you probably do, remove the sensor on the backing plate, (one wire and one 10mm bolt) Then remove the little black block from inside the differential itself, which is one long thin bolt), if you can't see the bolt, rotate the assembly around till you can. Once that is done, THEN you can push the axles in far enough to get the clips off. Then the axles will pull out with no resistance at all.
Good luck man, just did this myself, it was not hard once I found out about getting the abs sensor off.
