Stock Clutch
Power level, sticking clutch pedal, hydraulic system.
A new stock clutch didn't help because it uses the same crap pressure plate setup. An aftermarket clutch and plate will alleviate the sticking pedal. Nothing to do with power or hydraulics.
Yes, I know certain corvette "gurus" (lol) like to say clutch dust gets into the slave cylinder (bwahahahaaaa) and makes the pedal stick, uh, no. Its only a poor design exposed at high RPMs.
Hydraulic clutches are awesome.
Both stock and aftermarket gave me issues with a sticking pedal, the hydraulic fluid doesn't return fast enough to the release bearing under fast shifts.
You have two options, one is a bandage and one is the correct fix.
Lingerfelter sells a return spring you can bolt on your pedal
Or you can fix it right with the billet mcloed release bearing setup. It's a really nice piece, has braided lines, remote bleeder and a quick connect fitting. Also I suggest getting a small resivor off a quad or street bike rear brake setup and make it a seperate resivor as the stock setup has the clutch and brakes on one system and if you do like me and blow the stock release bearing apart you also lose your brakes.
Hope this adds some info to your search
I am not saying it's the same on every car every time, this is only what Ive seen.
your fluid should be clear like water or a very small tint to it. if its any bit brown and flakes floating around clean it out
gettin rdy to spray 100 to 150 shot . we will see how long it last . but i know a few doing the same and still on stock clutch . but also know 2 that are in the 600+ range and stock clutch didnt last long at all
