Actual Weight Differences in SS cars
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Curious what the actual weight difference are between 1SS strippers and full loaded 6sp manual cars and automatics.
I've already seen a loaded 6spd car tip the scales at over 4000 lbs raceweight. I'm guessing a loaded Auto would be heavier.
Anyone gathered that type of info yet?
found this just a few minutes ago..
1EE37
LS Coupe
Capacities
Curb weight, 3780
manual, lbs.
Curb weight,
automatic, lbs. 3769
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1EF37
1LT Coupe
Curb weight, 3741
manual, lbs.
Curb weight,
automatic, lbs. 3750
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1EH37
2LT Coupe
Curb weight, 3741
manual, lbs.
Curb weight,
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1ES37
1SS Coupe
Curb weight, 3860
manual, lbs.
Curb weight,
automatic, lbs. 3913
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1ET37
2SS Coupe
Curb weight, 3860
manual, lbs.
Curb weight,
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1EE37
LS Coupe
Capacities
Curb weight, 3780
manual, lbs.
Curb weight,
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1EF37
1LT Coupe
Curb weight, 3741
manual, lbs.
Curb weight,
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1EH37
2LT Coupe
Curb weight, 3741
manual, lbs.
Curb weight,
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1ES37
1SS Coupe
Curb weight, 3860
manual, lbs.
Curb weight,
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1ET37
2SS Coupe
Curb weight, 3860
manual, lbs.
Curb weight,
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1SS to 2SS shouldn't be much. The added electronics are mostly just programs in exsisting hardware like the radio and DIC, the 1SS has power seats too so it's just the weight of the leather and 4 pack gauges. The arylic dash and door panels maybe be lighter but that's made up with the added LED's. I would guess at or under 100# difference. The sunroof may add a few lbs. though but that's available on both.
My guess is once it's factored by NHRA, at probably F or G/stock, (stick) and G/SA (automatic), the raceweight may be at around 3800 w/a 165-70 lb. driver. It still remains to be seen, whether or not it'll be allowed to install a straight axle or make them keep the heavier, drag race-unfriendly IRS. Big problem there w/huge rear brakes for fitting lightweight smaller wheels and a real hooking tire.... Time will tell....a car this fast "looking" will definitely be made to go fast---no matter what the cost, by those who can afford to.....It surely would have made things a helluva lot easier, if they had offered a drag-pak option (50-100 build) like the Cobra Jet cars, w/a straight rear axle, rollbar, headers, good TB and tune, slicks and more....If the car sells real good, they just might follow Ford and offer something like that in the future...
WJ
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
