Anybody have a decent Trap to RWHP conversion chart?
I was wanting to get a good idea on what traps match typically with what rwhp #'s. I know it will vary but all in all it should be somewhat close and accurate to do comparisons. Thanks
I always use this calculator. It's pretty close usually, but definitely not exact.
http://www.wallaceracing.com/accel-calc.php
That website has a calculator for pretty much anything drag racing related.
To properly figure out drag strip trap speeds, you need the actual weight and rear wheel horsepower of the vehicle in question. Anything else is just pulling a number out of your ***.
Besides Wallace's site, I also use TCI's.
http://www.tciauto.com/Products/Tech...alculators.asp
I just used the wallace one and it was pretty close! My previous best in decent weather was 11.76 @ 115 on a 1.60 60'. That's pretty much right on. Of course a few weeks later the temp was in the 50's with a real low DA and I got the 11.53 in my sig ![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
But for a normal DA and temp it was right on for me. Just remember that the HP is FWHP. I put in my rwhp first and it told me 12.4 @ 108 LOL.
Power to Weight Ratio: 8.22
60 Foot E.T. : 1.63
1/8 Mile E.T. : 7.42
1/8 Mile Trap Speed : 91.63
1/4 Mile E.T. : 11.76
1/4 Mile Trap Speed : 114
1/4 Mile Trap RPM : 6,044
60 Foot E.T. : 1.63
Hmmm....was just wondering because I seen a couple guys talking about it in another thread and wondered if it was possible to get a good guess. Plus you always here people say...."what did you run?"...."O a 12.5"..."Ya thats about rite" haha
Then change the raceweight if you want and see how that affects the ET and trap. It's kind of cool. Hardest part is factoring in the 18% drivetrain loss since we are all so used to rwhp numbers here and not fwhp.
I plan on around 420rwhp @ least (Entered 500).... 2 shifts for my Stalled Auto..... And just threw in 3300 pounds for weight and got these numbers......
Power to Weight Ratio: 6.60
60 Foot E.T. : 1.52
1/8 Mile E.T. : 6.89
1/8 Mile Trap Speed : 98.60
1/4 Mile E.T. : 10.93
1/4 Mile Trap Speed : 123
1/4 Mile Trap RPM : 5,900
Seems like it may be a little wishfull thinking...... guess we shall see. If anybody has some more ideas to get a better guess for me let me know.
60 Foot E.T. : 1.52
60 Foot E.T. : 1.52
60 Foot E.T. : 1.52
11.35 @ 118
Now look at my sig. I run 11.5-11.7 with a 3650 lb raceweight and only 370ish rwhp. If I added 40 rwhp with decent heads and 65 lb for a roll bar then I'm at 410 rwhp, 3700 lb raceweight. Thier estimate of 11.3 @ 118 is about what I figure I would run by adding 40 rwhp and 65 lbs. Maybe 11.2 @ 119 in better air but certainly close enough to consider this a decent tool for estimating purposes.
If you have 420 rwhp and you actually are 3300 lbs going down the track then I fully believe 10.9 is there. Always assuming a half way decent DA.
But if your setup is well thought out (proper stall size, gears, tires & shiftpoints) and weather/elevation are decent then it should be close. At least it was for me.
I just ran it with mine and it seems pretty close. Said I should run about 12.02 @ 112. the mile per hour is good. To bad my 60ft times suck, and I'm a slow shifter. I need DRs and a driver mod.
