General LSX Automobile Discussion Non-technical LSX related topics.
Recovered My Stolen Car! But Will Not Start.
Old 11-02-2008, 07:07 PM
  #41
bamxbam's Avatar
Originally Posted by Mean87SS
so they give you C5 wheels???
Haha, basically... with crazy bald tires too. The ZR1s were just starting to grow on me too.. but the C5's look good too. They could have at least given me the full treatment . I think that was their plan, because there are two spare tires in my backseat right now that they left, so they were probably going to put them on later. What sucks is that they probably stole the c5's on my car from another fbody or vette =/.
Old 11-02-2008, 07:26 PM
  #42
98Camarod's Avatar
Maybe you should see if anyone is missing the c5 wheels in your area!
Old 11-02-2008, 07:33 PM
  #43
flintwrench69's Avatar
Originally Posted by Jmagliola
All you need is a certain kind of resistor - put it inline with the vats system (I think the two wires are orange) and it bypasses the "security" chip. The little thing in your key is actually just a resistor.
If you want, tomorrow I'll take pics of my fuses so u can match them up
Actually, the wires for the pass key resistor are 2 very small white wires wrapped in an orange plastic housing. Those wires come out of the bottom of the steering column. There are 15 different resistance values. Yes, you can read the resistance of the resistor on your key, bypass your ignition cylinder key reader by wiring in the same reading resistor to those small white wires, that go to the pass key module. The only way they couldve stole your car is either a tow truck, or hacked into those 2 white wires & installed the correct resistor, then broke the column to drive it. It will not stay running even if you jump the starter. It will start & stall. Sounds like the car is very fixable, but will need to go to a repair shop so its fixed properly.
Old 11-02-2008, 08:54 PM
  #44
9000th01ss's Avatar
Originally Posted by flintwrench69
or hacked into those 2 white wires & installed the correct resistor, then broke the column to drive it. .
Is it possible they hacked the correct resistor into the vats wiring in a way that when the key with the correct chip in it adds to the resistance value and thats why it's not starting? Maybe try a key with no vats chip.
Old 11-02-2008, 09:11 PM
  #45
Cole Train's Avatar
they would have had to basically tap into the wire and not cut it completely. Otherwise where they cut and put in the new resistor is where the signal ends and wouldn't make a difference on the key end. This is how i did the VATS bypass on my '96Z28. It worked and then didn't and i couldn't wait for the shop to get around to fixing it so i just bypassed. Took me half a day with going to Radio Shack for the resistors and then getting the resistance value from the key beforehand. Dealer said a week because they were busy(crap only 2 vehicles in the shop). To the O/P if the column peices are busted up and shattered(couldn't tell in the pics) then you will have to replace the column if you need parts check out ebay or www.car-parts.com . i hope this helps ya get the car on the road sooner though bro...
Old 11-02-2008, 09:33 PM
  #46
9000th01ss's Avatar
Originally Posted by ColeTrains'96Z28
]www.car-parts.com...
Thats car-part.com. no S.
In the pictures of the underhood fuses, the only one missing is for the horn (top fuse box pic).
The fuses in the car are all there you must just not have steering wheel controls for the radio. Those are the 1 amp fuses in my pics.
The empty fuse locations that are missing terminals are for options your car does not have. Like RH HDLP DR is for the headlight motor on a firebird/trans am (right hand headlamp driver)
Old 11-02-2008, 10:09 PM
  #47
Cole Train's Avatar
It works with or without an S in there.. thanks for getting this guy pics of the fuse boxes
Old 11-02-2008, 10:38 PM
  #48
9000th01ss's Avatar
Oh, it used to (I thought) take you to a generic parts accessory site, guess they fixed that.
Old 11-03-2008, 12:33 AM
  #49
Datzneat's Avatar
Is your starter relay fuse good? My buddies security system when haywire and he was able to get it going with a paper clip in there. Don't know if this helps but it's worth a try.
Old 11-03-2008, 12:40 AM
  #50
LS1nut377's Avatar
well glad to see you got it back.sorry it was kinda messed up,hope you get it going soon
Old 11-03-2008, 12:42 AM
  #51
squee's Avatar
I bet their sitting here reading this laughing...
Old 11-03-2008, 07:23 AM
  #52
RsSean's Avatar
Well like the guy said above the one that is not used is fine. There are a few in the fuse panel inside too. I wan't to say the one that should be used is the horn... Get me some pics of the cut wires and I will help you the best I can with just pics. If you were in Mobile AL. I would drive to help you, but New Orleans long drive. I agree with the slow butter knives.
Old 11-03-2008, 09:30 AM
  #53
squee's Avatar
If I had more time, I would help since I'm not to far away, but I've been really busy lately.
Old 11-18-2008, 09:28 AM
  #54
TheLSgun's Avatar
Get it started? Anything happen with your insurance company? Glad to see you get it back. That really sucks!
Old 11-18-2008, 09:30 AM
  #55
RsSean's Avatar
Yeah do you have any updates on the car?
Old 11-18-2008, 09:51 AM
  #56
bjamick's Avatar
I still dont see these thieves spending this kind of time to steal a car. You guys are talking about tapping into wires and all that good stuff. Now I can see the steering wheel locking and then they just use power to break that. Then the car is driveable, but I dont see them "re-wiring" the car so it will run. It would be nice to know exactly what there doing to get them so quick.
Old 11-18-2008, 09:53 AM
  #57
00badfnta's Avatar
Im glad you got it back since you only had it a few month. That one of the many reason I hate living in the New Orleans area.
Old 11-18-2008, 10:13 AM
  #58
BlackonBlackTA's Avatar
Just curious on your insurance. If it was stolen from your residence, can your homeowners insurance kick in, or does it just cover stuff that happens on your property? More I think of it, probably not. Just looking at options for you.
Old 11-18-2008, 10:43 AM
  #59
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
Originally Posted by 'Trust'
Recovery vehicles are usually considered total losses, are they not?
^^^^^ Thats what I've heard aswell but I didn't know if it was true.
Dude, You are one lucky som of a bitch. Glad they found your car.
Old 11-18-2008, 12:46 PM
  #60
bamxbam's Avatar
It was stolen from school so no, homeowners insurance won't have anything to do with it... not like we have it anyways, we rent. Auto insurance will have to take care of it, and the deductible is $1k.
I originally started this thread to get some ideas to start it myself, but the thread ended up dying after I took it to the dealer anyway. But might as well give an update! It is currently at a Chevy dealership getting worked on, as of today, it has been there for exactly a week, and they're still waiting for parts to come in to work on it. All I know for now is that the steering column is being worked on/replaced, getting replacemenet wheels and tires (replica ZR1s... but I think they look the same except for the wheel caps), and hopefully they can fix the VATS/alarm system back to normal. I sure hope they know what they're doing. I also need a new stereo headunit too, which will be covered by insurance, but the dealer said they can't do it so I have to take it somewhere else afterwards. The wait is killing me! I just want to drive the damn thing again, but good thing I still have my beater 2002 ford escort zx2.
Question. What would you guys do? I obviously bought the car to enjoy and drive as much as I can, not just sit and drool over it like some others do. If I start driving the Camaro to school again it might get stolen again since that's where it got stolen in the first place... but... if I leave it home and take the beater as a daily driver instead, the Camaro still has just as good chance of being stolen right off my driveway since we don't have a garage, and the street in my neighborhood is pretty quiet. My plans after getting the car back is figuring out a way to install a kill switch or just get the Ravelco system, and using a steering wheel lock to deter any more attempts, although if they really wanted to, they will just tow it. I know there will be mixed opinions on this, but I'm just basically trying to justify my reasons to keep driving it whenever I want
Quick Reply: Recovered My Stolen Car! But Will Not Start.
