View Poll Results: What are your opinions?
Royal Purple
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
108
45.38%
Mobil 1
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
130
54.62%
Voters: 238. You may not vote on this poll
Royal Purple or Mobil 1?
#81
I have been using Mobil 1 because I thought it was good. I just may switch now. Have anyone heard of castrol edge ? its there new synthetic that says it offeres 8X the protection of mobil 1.
check it out
http://www.castroledgeusa.com/
check it out
#85
Try GC. Should quit burning it and stop the piston slap.
#86
Well I used Mobil 1 for a while. Just put Royal Purple it today. My friend put some in his camaro, and he said that he noticed a difference in performance right away. I don't know if I believe it or not so I guess I'm just going to have to wait til I drive the t/a again and find out.
#89
so confused
well When I bought my car the prev. owner had that castrol syntec ****, *the one thats overadvertised and was taken to court I think* in it :same guy that tried to tell me my ride was a 35th anniv. package
and I promptly switched it to M1 after reading about the alligations, Now I've always run M1 full syn basically because the old man Swears by it and is a bmw nut, I ran m1 in my first car an older bmw it burned like crazy in that thing! Moving on, The LS1 Is super Fin' loud with the m1 and it gets dirty quick.....I am just Grrr....Sounds LIke I need to Change bloodtype again! this is the same Old man that talks **** about my car and tells me put whatever you want in your chevy but I only use m1 in my bimmers.. but that's prob. because its faster than his 90's bmws...
So Should I go with Pennzoil Platinum or valvoline synpower. I've always suspected they are better than m1 but no one wants to admit it, Im weary of the castrol line but I hear nothing but pure gold of the GC. I put Pennzoil platinum in my tahoe for ***** instead of the usual and it runs smooth but I had to add a quart really fast... trucks burn faster I guess? Looks LIke I gotta pry off that brand new M1 engine bay plaque and get rid of the 2 ******* Cases of m1 5/30 i got for my birthday......
oh yeah, Sorry for
if that applies. On A Final note, I change my oil every 3kmiles or sooner if needed I check the color 3x a week
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
![Hijacked!](https://ls1tech.com/forums/images/smilies/myhijacked2.gif)
#90
Let me shed my thoughts on this topic. I actually used to work with a guy several years ago and his uncle was the inventor of Mobil 1. He sold his rights to mobil 1 and has since statred another line of oil. Guess what it is? Royal Purple Thats correct but up until a few years ago the oils were identical with the exception of purple dye. But in the past couple of years mobil 1 has took the cheap route out and took some of ther detergents and other fain ingredients out to save money and the oil has not been the same. I have a really good friend of mine right now what works for penn that used to sell for mobil and he would give me mobil for my vehicles and my drag bikes. I started burning up clutch plates and could not figure out why? well the verdict was the oil.... (Mobil 1) he told me that they had changed the formula. I stoped using it and started running alyson oil....NO MORE PROBLEMS....But to answer your question....I would use Royal Purple....Its the first original formula. But I would consider amsoil or alyson
My Thoughts;
Scottie
My Thoughts;
Scottie
![Thinker](https://ls1tech.com/forums/images/smilies2/thinker.gif)
#91
so confused
oh yeah, Sorry for
#93
I believed the mobil 1 hype and this is what its done.
1) z06 ticking sound
2) Lightning puffs grey smoke on start up @ 71k miles
3) 04 F-150 used mobil 5000, burned 2 qts and went to advanced to buy more.
Clerk says "2QTS?" "you got an oil leak"
ME... "No I don't." (clerk) Yeah you do dude!
ME...No I don't DUDE!! my drive way is spotless. Clerk...Your not lookin hard enough
ME... Just give me the damn oil
#94
I get Jiffy Lube synthetic FOR FREE since I used to work there. I just started running it and it's fine. I change my oil like every 1500 miles since I bracket race it. I used to use M1 but heard about all the crap.
#95
#96
My buddy just had his TA built and his builder suggested Valvoline Syn without the energy conserving rating because it has a high friction modifier content. That's what I use and at 120k I never have burned up oil. Used but not burned up like Mobil I used in the past. If I had the $ Purple all the way!
#97
I tried the German Castrol my car was louder with it then burnt up Mobil 1, now i stick to valvoline synthetic. Imy dad has run that in his dodge ( and several other vehicals ) the dodge has 165k miles on it, and we had the valve covers off to change the gasket and it was CLEAN other then the red tint from the oil there was no gunk, no grease, nothing, and it was still clean just red. Thats what i run that castrol 0w30 ive been recomended several times i had it in for probably 2-3 tanks of gas and it was already getting bad.
The only thing i liked from M1 was there 2R two stroke oil which was easy to get and cheap and worked well. then they quit making it without any reason.
#98
Heres where im lost-
You guys are saying Mobile 1 is ****, ok thats fine, and for some reason doesnt offer good protection. Now this castrol from germany, would this not be too thin of an oil? *Please note that my car is ONLY a evening summer car, therefore it doesnt see any cold weather start ups at all.
Would I still benefit by going to the German produced Castrol even tho its a 0W-30?
#100
either way. no. GC is a thick 30 weight oil, which is exactly what an LS1 likes. the 0w is just its cold rating. 100 degrees is ice cold to a motor that operates at around 200, FYI. you want a thinner oil on startup, so it will travel around the pistons, etc, easier. once it warms up, it becomes a thick 30w, almost a 40w.
one of the many problems of M1 5w30 is that its extremely thin, more of a 20 weight then 30. their 10w40 is better, but still far inferior to GC or other quality oils.
