General LSX Automobile Discussion Non-technical LSX related topics.
stock 10 bolt weakness Q
Old 02-24-2009, 11:14 PM
silverM6TA's Avatar
dont listen to anything anyone says on here. a stock 10 bolt WILL HOLD UP!!!! lmao
Old 02-24-2009, 11:19 PM
ballerchris510's Avatar
Ive beat the crap out of my 10-bolt with heavy 18x10.5 c5 z06 wheels and nitto 305/35/18 launching, dumps, crazy 1-2 shifts and its all good but i guess luck has to do with it but u WILL be fine unless you put mt dr then u have to be carefull... but then again my best 60 foot is like 2.0 horrible but the car is lowered so that dont help hook... but now im saying **** why did i write this i hope i didnt jynx my self lol... na i have hope in my little 10-bolt
Old 02-24-2009, 11:24 PM
I should of stated my car makes 450/530 on a 100shot to the tire... also my M6 broke shitty keys but now there billet before the rear did...
Old 02-25-2009, 12:10 AM
ss69's Avatar
Originally Posted by 1SLwLS1
The 7.5 is pretty small. The Ford 8.8 can be made pretty strong for cheap. Anyone ever heard of any swapping in one of these? You can pull one of these out of a Ford Exploder with a trac lock, 31 splined axles, and 4.10s for next to nothing
That's what I'll be doing. I've got an extra 10 bolt that I'll be cutting all the brackets off and using on the 8.8.
Old 02-25-2009, 12:11 AM
4WOFURY's Avatar
My 10 bolt is holding fine for the moment, but I do worry about it all the time.. to a degree. I'm putting down 420rwhp through a 10 bolt, with 4.10 gearing. I have stock suspension, but heavy *** 18x11 inch rear tires with a 295 GSD3. I don't dump the clutch, but I have launched at 1500-2k (well.. slipping the clutch till I get rolling a little then letting it out and stomping the gas), chirped tires, and done burnouts.
Old 02-25-2009, 12:31 AM
96lt1m6's Avatar
a few have done the hybrid 8.8 but i feel the time and expense would not be worth the time vs. saving the money for an S60,12bolt or a 9
Old 02-25-2009, 12:44 AM
'Trust''s Avatar
I've had 3 cars with 10 bolts at various power levels. Here's how we go:
Car 1 (98' T/A): Small H/C stalled A4 car, 392 RWHP 373 RWTQ, stock 3.23 gears. 1.7X 60's, numerous times, ran 12.1's, zero issues.
Car 2 (01' T/A): Bigger H/C stalled A4 car, 442 RWHP 420 RWTQ, 4.10 gears, 1.60 60', numerous times, ran mid 11's.
Car 3 (00' T/A Current car): 396ci D1SC stalled A4 car, 653 RWHP 63X RWTQ, stock 3.23 gears, 1.44 60' (backed up with several 1.4X 60's), low 10's. This car is heavy and leaves hard, 10 bolt is now whining pretty bad and the 12 bolt is going in this week hopefully.
My personal experience and opinion: If you're making sub 500RWHP and in an A4 car you won't have any issues with any kind of racing. If you are making 500RWHP in a M6 and have STOCK GEARING, you'll last a while at the track and shouldn't have any issues with a roll. Anything over that on either, get a built rear. Rule of thumb, IMO, don't invest money in a 10 bolt.
Old 02-25-2009, 12:52 AM
Ironxcross's Avatar
You A4 guys are lucky, haha.
Old 02-25-2009, 02:16 AM
elias_799's Avatar
just don't throw on tires bigger then 285's and especially not slicks and you should be fine.
Old 02-25-2009, 06:50 AM
SladeX's Avatar
russian roulette....
I've broken them without trying.
My latest 10 bolt is "holding" I say that despite the fact it HOWLS loudly during turns (posi issue). On the plus side it's survived 4k clutch dumps and 200+ drag races. Not to mention the WOT runs on a roll...
Old 02-25-2009, 09:04 AM
hj99Z's Avatar
I'm at 350 whp and mine is just about broken, all i do is roll race. But i do have 150,000 Miles so it may last you, just not for too long.
Old 02-25-2009, 01:33 PM
  #32
Arc00TA's Avatar
My .02, I have a 10-bolt with 3.23s in my car, it makes some noise but not much, I think the bearings more than the gears. I beat the everloving crap out of it and it never give me a hard time. I never launch it hard though, so I think the issue is with the small ring and pinion being flexed by a hard launch with no "give" i.e. crappy tires spinning and not hooking, then it just gives up.
Old 02-25-2009, 07:26 PM
  #33
SOMbitch's Avatar
The biggest issue I think is there is no torque arm mounting point.
Old 02-25-2009, 07:37 PM
  #34
KnightmareLS1's Avatar
10 bolts are GARBAGE!!! You might be one of the lucky few who's lasts a little longer but it's on borrowed time! I thought I was good if I didn't launch hard and kept spinning I had my Spec 3+ in for about 2 weeks and one good 1-2 shift and BOOM!!! If it lasts you're a lucky SOB!!
Old 02-25-2009, 07:43 PM
  #35
78novacaine's Avatar
i bought my car with 95k, it now has 125k on it, stock 10 bolt, stock gears. i have always ran street tires, but it hooks up pretty well even on those (several 1.9s, a couple 1.8s, and one miracle 1.7x) and i abuse the car on the regular, and prefer dig races over anything. as long as you are running from a roll the majority of the time, and you keep the stock gear, you should be fine for quite a while
Old 02-25-2009, 07:44 PM
  #36
NSSANE02's Avatar
That's the best answer you'll ever get. People ask this question all the time but the answers you get are really only opinions from people speaking from their experiences. I've heard of people running into the 10's and having no issues (VERY rare btw) but I've actually seen several bolt-on cars break them (including myself...from a roll) and my friend broke his on street tires, from a 40 roll, with only LT's and TD's. So... do you feel lucky punk?
Old 02-25-2009, 07:49 PM
  #37
silverz28camaro's Avatar
The problem with that is you woulld have to fab up all the brackets, then your breaks, then you have to find a way to make the torque arm work, If you did 2nd gear rolls and had roughly 400rwhp it should last,
Another thing to consider is weight reduction, the lighter the car the easier it is on drive train components.
If you get a hard top car without power seat, and all the fancy wheels that come on the ss ans ws6 cars that alone can save nearly 100lbs.
16inch rims are eaisier to turn then 17's, I think there were a few ls models that had a stripper setup, some of those cars didn't have power windows, or rear defrost.
The camaros are also usually lighter then a trans am, (no headlight motors)
Something to think about.
Old 02-25-2009, 07:55 PM
  #38
just an fyi, the electric window motors are actually lighter than the manuals
Old 02-25-2009, 11:19 PM
  #39
Nitroused383's Avatar
I think my 10 bolt is going to explode on the 1-2 shift. It would clunk really bad when I hammered down on the 1-2 shift, but I replaced the torque arm bushing with a poly unit. The clunking went away and it doesn't hop at all. It sure feels like it is hard on the rear end though.
Old 02-26-2009, 12:24 AM
  #40
nalmak's Avatar
same here..but on 2-3..vibrates like crazy..shakes the whole car
Quick Reply: stock 10 bolt weakness Q
