stock 10 bolt weakness Q
Will the stock 10 bolt handle 400rwhp and roll races? I know it will bust with hard launching, but what about roll races? I know it will inevitably endure a 9" upgrade, but I would like to roll around with the 10 bolt for a while
m6 10 bolts gernerally die sooner than a4, but there are alot of factors that go into it, what suspension, what tires and what kind of luck you have.
ive seen a FEW ten bolts in the deep elevens, not very much, then ive seen them croak before people break 12's. so its a wierd thing
People on here are bias against the 10bolt lol. True it isnt a super strong rear but it comes down to this. If your on street tires, you shouldn't worry much about it, if doing clutch dumps often, that would probably hurt the clutch more then the rear if its still on street tires once again. Now on the other hand if your trying to get traction by having drag radials or slicks.. then your on borrowed time, thats the type of bullets that hurt the 10bolt.
oh no, I will make that 10 bolt work as long as I can. I never go to the track. I have had this car(sig) for 2 1/2 years with the exact same power for the last 2 years and never taken it to the track. I dont like 1/8th mile and the closest 1/4 I know of is Baytown. So this will see soft tires for quite a while
The 7.5 is pretty small. The Ford 8.8 can be made pretty strong for cheap. Anyone ever heard of any swapping in one of these? You can pull one of these out of a Ford Exploder with a trac lock, 31 splined axles, and 4.10s for next to nothing
it all depends on how you treat it. i know several people, me included that
have gone deep into the 11's with 10bolts. AVOID wheel hop, thats a must. and cheap insurance add studs, to the mains, and use girdle cover.
theres a 3rd gen running1.4 60s and 6.3s at 105-110 in the 1/8 with a stock 2.73 10bolt with these 2 mods. it can be done. AVOID AVOID AVOID wheel hop
