Offset axle bearings
So, i had to replace my axle bearings, and the parts house convinced me that i would have to go with the offset axle bearings as it was almost guaranteed that the axles would be f$#ed up, so i get them and put them in, and the axles don't look too bad so i figure what the hell, besides, now my rear end is out and i can't get back to the parts house for the stock bearings. So i go ahead with plan A. Big mistake, after getting it back together, the seals leaked at less than 25 miles![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
WTF???? i prepped the axles and everything, so to go from bad to worse, just try getting those ******* c-clips back out![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Freaking hours with the die grinder and making sure i don't jack up the axles or spider gears. Never again. I went back to the stockers and just put 400 miles on without a hitch, plus, while it was apart this time, i rebuilt the rear end. So, you think you had a bad day????LOL...live and learn
I'm not finding that bearing on NAPA's site. I may just have to walk in and see what they have.
Oh and there is a Carquest here. Closer than NAPA actually. Cool, I'll check there first.
Only 800 miles?!
So.... I guess carquest it is! I hope the one here has the offset bearings.
Only 800 miles?!
The bearings i used were BST or something like that, got them from Napa Auto Parts. The bearing and seals are one. They looked good, but the final results sucked, Plus, i've been wrenching on cars for a long long time and i knew when i finally got the c-clips back in that if i ever had to take them out again it was going to be a pain. I just didn't think it would be the next day. This is just my opinion, but if your axles are bad, your better off coughing up the money for new ones, rather than go through the bull#@t the i had too. The really bad part is the car only has 77,000 on it and the bearings have been bad for awhile. Seems to be a trait on the 10 bolt
I think I have a bearing going out on mine as well, I am going to pull the shafts and take a look. My options are GM, Napa, Autozone, or Advance Auto Parts. I guess I will see what is needed when I look at the axle shaft...
The sound I am getting is on right hand turns, sounds like a flat tire or something - kind of like "wahwahwahwahwah" sounding.... Best I can describe.
