Advantages vs disadvantages with speed density
I was condsidering going to a speed density setup but i was just wondering what are some of the disadvantages with this set up?
well my car is "stock" but not stock put it this way it sounds like a damn vaccum is in the intake lid, and before i go spending $$$ on a fast intake, i was wondering if its worth going to speed density, i got really good "stock" heads and a great built "stock" bottom end but straightline told me the ls6 intake is holding the car back, the car is driven on the road but only in good conditions,
My 92' V6 Camaro was speed density. I've had four cars since then, all of which had or have a MAF (86 Olds Cutlass Ciera 2.8, 88 Pontiac 6000 2.8, 97 Olds 88 L36, and my LS1). I have to say, that 92 ran the best out of all of them. I swear the lack of an unreliable MAF sensor had alot to do with it...
The MAF is very reliable and accurate as long as it's not pushed beyond its capability.
I drive my Open Loop Speed Density tuned car, from 4500 ft. to 10,000 ft. in 0 degree wheather to 105 degree wheather and have no fueling issues what so ever.
The IAT sensor deals with temp. and the MAP sensor deals with altitude.
These sensors remain intact in a OL/SD tune and deal with any changes for temp. and altitude.
If a vehicle does not run correctly when the altitude and/or temperature changes, then the tune has not been done completely/correctly.
Chad
Jedi Master
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
