Something messed up
Something messed up
So I was messing around with my friend to day and I hit the gas in a parking lot and there was a loud bang like I hit a pothole or something. Anyways something is rubbing now, it sounds like the tire rubbing but I look under there any saw nothing out of the ordinary. I jacked up the rear and spun the tires, once again nothing seemed wrong. When I am going about 20-30mph the car vibrates horribly, when I let off the gas it isn't bad anymore, and when I hit the gas sometimes there is a popping sound. Also when I push in the clutch it feels and sounds like the driveshaft is spinning crazily. It's like my driveshaft is about to fall out or something.
Anyone know what's wrong? It seems like it's the rear end or drive shaft, it's in that area. Maybe later I will jack up the car and get the tires moving and see if I can see anything.
It sounds like a u-joint. It happened to me and made similar noises. At the time I really didn't know any better and ended up breaking a u-joint doing a 45 in a roll race a with a 04 maxima on the highway, the car was making funny noises for a week like the ones you described and when that u-joint went. I dropped the driveshaft stripping the spider gears in the rear axle and blew the plate right off the axle. It was so embarrasing.
$1687 laters. I will do my own repairs and wont drive my car when its making funny noises.
U joint is my guess. When tranny mounts go it bangs under the console not towards the back of the car. When a T/A mount breaks you usually trash the rear though maybe it could be loose especially if you have a Moser..... The T/A mount usually breaks at the front too....
Where is the U Joint and Torque Arm? The U Joint has something to do with the drive shaft correct? I have never worked on this part of a car before. Anyone have any pictures of what I need to really be looking at?
Also I just made a couple videos and when I hit a bump or made a turn I could hear something hitting the floors or rear tub area of the car(t-top place).
then the lower control arm mounts and bushings, and then theu-joints, drive shaft, yoke and driveshaft pinion mount.
Good luck
It ended up being the torque arm. The top side was missing one bolt and the other bolt shredded the hole. The bottom bolt closest to the rear was starting to tear. We welded a piece of metal to the top hole to close it in and help hold it together and then we welded up the bottom hole, should be fine for now.
I don't know if it's my mind playing tricks on me or what but my car seems to handle and ride better now.. Anyways I am just glad to have my baby back.
