oil on spark plugs
LS1Tech Administrator
Received 1,775 Likes
Excessive oil is entering the combustion chamber, either via the valvetrain (valve seals, as mentioned), or past the rings. Rings are more likely, usually valve seals don't leave wet plugs, just enough oil in the combustion chamber to cause some smoking on startup.
Last time I dealt with oil on the spark plugs, it was the valve cover gasket. But then again, that was on a mitsubishi 4 cylinder and the spark plugs go down into the valve cover, completley different from our motors, so IDK why i'm posting this.
Douchebag On The Tree
padding that post count....oh sweet, mine rose too!?
