Need your LS1 Trans Am Knowledge
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
Alright im looking to sell my truck and get something with an LS1 in it, right now i have my eye on a 98 trans am with an LS1 in it, and im just coming to you guys for opinions on the engine, and common problems with the year, model, engine etc. Any suggestions for me to ask the seller before i consider this?
Basically i know nothing about the LS1, or trans ams for that matter.
They're all the same really, from '98 to '02.
There aren't significant differences between the years to really make on year stand out more than another. Just check the overall health of the car and make a decision based on that and how much you like it. Also, I'd check and see if the seller has any maintenance records, 'mods, etc.
LS1Tech Administrator
Received 1,685 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Any year LS1 is a good year. The '01-'02 are really nothing special, they probably make 10hp more stock based on the combination of the LS6 intake, slightly better flowing heads, and better exhaust manifolds (this actually started in '00). There is nothing magical about the later years, although some of the '01+ owners like to think there is. Coming from a person that currently has both a '98 and an '02, the power difference is so slight that you can't even feel it.
Personally, I'd be more concerned with mileage, overall condition and price than with model year. All the years have some very subtle advantages and disadvantages over the other years, so there is no "perfect" year that offers the best of everything stock.
Location: The dirty taint of the country. ...Los Angeles
.... 98s have heads that are a bit different from 99-00 & 01-02s. Something pretaining to to bolt patern being different from it's future years. Meaning, if you need new heads or upgrade to different heads, you need to search for 98 specific heads. Can be a bitch if your not accustomed to part hunting.
.... Oh, it uses a different PCM. So if you ever god-forbid have PCM problems that requires a swap, you need to specifically find the 98 version whereas if you had a 2000, you can swap to a 2002 version without any issues. ...
.... 98s have metal tanks whereas 99-02s use lighter, hard plastic tanks.
Hope this helps!
Hope this helps!
I would not avoid a '98. I have zero PCM problems with mine. A '98 PCM is no more likely to fail than any other year.
I do believe Frost posted a while back about maf issues affecting the trannys on 98s a while back.
I have drove mine everyday for a long time, I would still buy it but I wouldnt look for a 98.
Avoid= be very weary of one
The only real issue with the '98 PCM is that it's a little harder to tune for serious forced induction setups. But it can still be done by any decent tuner, and more basic setups are really no problem at all for a good dyno tuner.
Again, I just disagree. Most of the things people complain about with '98s are false rumors, misleading info, or not even specific to '98.
98-00 have a more radical cam, 01-02 have the ls6 intake manifold. Never saw any real proof that a certain year dynoed higher. M6 cars will dyno 300-315 at the wheels, and yes they were underrated. All ls1's are around 350hp at the engine.
There is a head casting number if you are looking at a 2000 to get. I think it's 241 is what you want. My gf's car was one of the unfortunate 853 heads which are not horrible I've just heard 241s are better stock for stock. At least the 2000s have the more aggressive cam in it. If you plan on making NA power I'd at least get a set of 243s or some aftermarket.... I'm sorry, I'm rambling, what to look for now.....
Make sure if it's a t-top it seals in the rain (pour water on it) and the window seals as well and sit inside while a friend pours. Might save you a lot of headaches. It's the little things that kill. Good luck.
basically what everyone else says. 01 and 02 have upgraded to ls6 intake and don't have EGR on them. Also I'm sure since the 4th gen was for 4 years the latter years have more of the bugs worked out than the 98 and 99's had. My cousin has a 98 and everything was great no issues with his it all. so its really a hit and miss. just check mileage and background on the car and listen for any weird motor noises. Piston slap commonly occurs on cold startup but should die out after a few minutes. Lifter tap(slight) is pretty normal. Mine does it every so often and goes away. Nothing really to worry about. these cars arent' exactly "QUIET" so don't be too alarmed.
