What is needed to lift the front end?
If all you are wanting to do is lift the tires then you can do it with your current mods. I would start with Double Adjustable shocks on all 4 corners. Also try to get some weight off the frontend, sway bar and mounts, maybe AC, bumper support, lighter battery or relocate kit etc..
Haha this reminds me of my friend who bought an 01 Z28 and his mod plan is to "keep modding till it wheelies"
Good luck on attaining your goal.
If you want to lift the front tires I would focus on the suspension setup. You mods seem like more than enough to lift the tires its just a matter of hooking and putting it to the ground without spinning.
i pulled the wheels off the ground friday night on the street,i have stock shocks/struts(141k), no sway bar, lca with relocation brackets, adjustable ta, sfc, greg weld 17in fats and skinnys with mt et streets, and a 150 shot.
My 250lb friend was able to pull one tire with stock wheels and stock suspension. What he did was remove the front swaybar, use 16x8 stock wheels with street tires on the front, 16x8 wheels with MT ET Streets on the back, and got good at launching his car... Milled 241s, 228R-like cam, lid/exhaust, stalled auto, 3.42s, hardtop. Best 1/8th mile on that setup was 7.4 with 1.6 60's
yea but i was sayin you aint got to spend a lot of money on parts you dont need like shocks bat relocation ect.... i also have the true et street not drs,and ive also pulled my heavy *** 17x9s off the gound at the track.
