97 Corvette - 327 whp- cam,exhaust,lid
My buddy has a 97 corvette a4 with 60k miles. He recently did a lid, full exhaust w/cats, and a torguer v2 cam (232/234 .595 .598 114lsa) w/supporting mods; springs, retainers, pushrods. Hes still on the stock ls1 intake and heads. After getting everything installed he went and got a dynotune and put down 327 whp/341 wtq. It was roughly 80 degrees out and 250' elevation. I don't know what kind of dyno he used nor how many pulls he did for the tune.
My question is, if he upgraded to the ls6 intake and got the 01/02 ls1 heads, would he see a 25-35 rwhp increase? I only ask cause hes pretty disappointed with the results and I'm thinking the older heads and intake are restricting his flow leaving a few ponies on the table.
What do you guys think?
Thanks for any and all input
that is low!!! just double checking what do you mean by full exhaust? headers too!! like someone else said his best choice is a fast combo or at least a ls6 intake and a ported TB but i will throw in some 243 or 799 heads and that will give him the 400rwhp with a 90/90 setup
It does seem to be low but I really think the intake and heads are holding him back. I'm going to ask which dyno he got it done on but til then. More opinons welcome.
LS1Tech Administrator
Received 1,685 Likes
I don't think so. The older heads and LS1 intake won't hold him back *that* much. I made 360rwhp through a cammed '00 LS1 Trans Am with stock heads & LS1 intake, plus A4 trans and unlocked stall. I had headers too, but they were mids (although I had an ORY). The IRS will eat more power than an F-body solid axle, but I had a very small cam (221//.558 single pattern).
Is this a white one? I've seen a white one run at Oxford Plains Dragway that was unfortunately running pretty slow, and didnt spin or anything. My times were better and I was 100% stock.
I got a 225/229 .580/.590 114 cam with LS6 intake, longtubes, and cutout. Did 359/346 on a Mustang Dyno.. Just for comparitive purposes. This cam is slightly smaller than the Torquer V2
However, it's still true that even for an A4 the numbers are very low.
Is what a typo?
Yeah. My z is bolt ons only and put down what ya see in my sig.
Why would you do that, then wonder why its down on power?
Yup, he has long tube headers w/cats and a catback exhaust system.
It does seem to be low but I really think the intake and heads are holding him back. I'm going to ask which dyno he got it done on but til then. More opinons welcome. Theres a noticeable difference with an LS6 intake about 10-15 whp over the stock one but I cant say for sure about the heads. I heard the 241s arent much better than the older castings. Some A4s will dyno low but run strong numbers at the track, but still with that cam it should be much closer to 400 whp.
Not a bad idea to check this. Something is definitely going on with that car, so might as well check the basics before getting too worried.
