procharger vs h/c/fast
So I may buy my old Ws6 back. It is a forged 347 P1SC kit with bolt ons stock heads 222 cam headers full exhaust. makes 10lbs of boost and should be high 500's rwhp. It did feel a little doggy down low. I am looking for a fast stop light to stop light car, not a high end track car. Car has a 3.73 12 bolt. So should I keep this set-up or go with a 228/230 cam, AFR or Trick flows and a ported fast? My tuner claims this blower is parasitic down low and they really don't make mych boost until 3500rpm.
I'm not a FI expert, but it seems suprising to me that a supercharger is laggy in low rpms since it's belt driven...is there a smaller pulley available to increase boost for your blower? Maybe that coupled with the different cam will help give you what you're looking for.
bought the kit used and it came with P1SC. The blower is a 3.4 pulley about the lowest one wants to go otherwise big time belt slip. I would just think a stout h/c/I may hit harder down low and go??
Anyway yes, from 3.42 to 4.11, I definitely jumped out across the line much faster without that initial heavy, lugging feel. Of course, you shift into 2nd sooner as well, but it feels normal and right. And the throttle response from the cnc ported tb was also noticeable.
500 RHP and it feels 'doggy'
You are not dumping the clutch correctly, you should be able to make women cry with that kind of power. Come one man, DOGGY? hahaha
Big, Sticky, Meaty - Tires.
