What mod/upgrade should I get next?
Mods in my sig, I'm wondering what upgrade I should make next. Wether it be appearance, suspension, or engine
But heres a more accurate description
- I don't want to lower my car, due to my wider tires.
- stock pads/rotors & original ss suspension
- I intend on getting a electric cutout added on my manual cutout
- no free mods
- 28lb injectors
- stock wires & idk what plugs
- I have stock pulleys
- no nos & i intend to keep it that way
- no hids
- stock monsoon
jus want opinions, any help will be appreciated
- no free mods
- 28lb injectors
- no hids
- stock monsoon
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Depending on what you want out of the car bilstiens would be a good inexpensive choice for decent handling and good ride quality. You can step it up and get some Koni SA's for more money, and get drastically improved handling, stability, balance and feel while having a firm, german sports sedan like ride quality as well.
If you want them for looks, then sure, but just check them for cracks over time. For performance go with good blank(like brembo) or slotted only (no drilled) rotors with some good (hawk HPS for example) pads.
Drilled do nothing for performance and you risk them cracking, especially the cheap ones.
The big question is what do you want out of the car specifically?
