Aeroforce interceptor gauge owners...
Torque OBD
Purchase a OBD Bluetooth adapter on ebay and create a vehicle specific profile and you will be quite suprised how accurate this tablet program is. I really enjoy mine and no battery drain!
Im getting one of these as well, and I was looking at the install instructions. do you need to plug in that 3 wire connection anywhere? or is that 100% optional? If not, where did you run the red wire too and where do they other 2 pins go?? thanks
I have the dual gauge setup. I like it but I'm not convinced the Aeroforce sending units are completely accurate. My fuel pressure readings are 2-3 psi lower than what my mechnical gauges show. Not a major deal as they're pretty good beyond that.
I'm pretty sure you can set the gauge to scroll through multiple parameters of your choice if you want to display more than 2 settings per gauge.
I was monitoring the reading for a while because I had o2 sensor codes all the time. The scan gauge will tell you the readings of them so you can see if they are in the acceptable range. Turns out they were fine it was my tune that was no good.
Can anybody confirm the installation of this gauge? If you just plug the main connection into the odb2 port won't It always have power? Do you need to run that 3 wire connection to a switch power line?
