how to remove oil and dirt
LS1Tech Administrator
Received 1,685 Likes
I ended up using engine degreaser from O'Reilly's. Used it on my 99 and 00, worked like a freaking charm. Like the guys above said, there may be some spots that have heavy deposit and you might need to scrub them but the product I used was amazing, made the damn car look like I got it off the lot. Autozone has one too but you can only use it when the engine is cold. The one from O'Reilly's isnt flammable and has to be used when the engine is hot, which is when all the junk in the engine bay is loose and at it's easiest to get off. You wont be disappointed.
I like Grease Lighting with the foam nozzle, I think it breaks down the grease a bit better.
I use both though, I use simple green with the nozzle set to stream to blast the stuff off (I use it really liberally) and the grease lighting to soak large areas to be scrubbed.
I tooth brush is really useful and a steam cleaner is great tool if you have one available to you.
If I'm blasting tying to get some stubborn grime off, I will cover the injectors and coil packs with a bag to prevent any water from spraying on them.
my engine bay is full of oil and dirt i tried removing it by a high pressure water sprayer but didnt work any advice ???
