Easy way to avoid breaking your oil pressure sensor during intake swap
Im sure someone else has thought of this, but I've never seen it posted.
Last time I did an intake swap I just removed the oil pressure sensor before I pulled the intake off and then waited to put it back on till I put the intake on.
It might be an extra step, but it saves you from buying a $50 part if you're not super careful.
If I remember correctly, you'll need a 1-1/16 deep socket to get the sensor off. Someone back me up on that though.
Edit: see post 8 to see a better way than ^
Youre right, it is a longer than standard 1-1/16 socket. I found the one I used in my toolbox and it's definitely longer than standard.
I'll always use the socket since I have it though.
I just did a intake swap and was super careful not to break it when i pulled the old intake off, but somehow when i put the ls6 on i broke it. Had to go get a new one and bought the socket 10bucks. I installed it and left the socket covering it until i was done. Worked perfect.
I just did an intake swap this weekend, instead of removing it I just unplugged it and was able to reach around the driver side and lift up on the big vacuum line port and lift it up the tiny bit required to clear it.
That's how I'll do it from now on.
