Kinda Lost as to what my Engine is
#41
Any siggestions on replacements?
#43
That is an awesome find! Congrats
I know a couple of people have said this all ready but it might be worth changing the valvesprings since you aren't sure how many miles are on them. We carry BTR spring kits and offer an LS1Tech discount! Let me know if there is anything I can do to help!
#44
#47
Disecting it further.. Was replacing the worn valve springs.. found they were bent and distorted. I can squeeze the old springs by hand about 5/8" the new ones barely move past a 1/8"
Cleaned up the pistons, part number says "custom piston"
Cumbustion Chamber, heads say "6.0" in the casting on the underside. So it's a 243 or 317 head?
Now here is where my luck has run out.. valve tip is jacked up on ONE valve. Patriot valves and pretty sure they are out of business. Not sure if I want to spend the money to get a new set of valves as i am sure it's not good to mix and match.
using crud methods of measuring.. it is a 3.999 bore and a 3.995 stroke. Making it roughly a 402. After reading about other similar engines they say the LS6 intake is too restrictive so my theory on the FAST 92/92 picking up more than 15 whp may be more fact than theory.
However there could be a cumulative increase with the new intake, TB, new valve springs. I'm not ready to freshen up the bottom end, so that will be the only thing the same. Except possibly the heads. i might lose power if it's cheaper to throw on some stock heads than buy valves and rebuild these
Nice Stainless valves once cleaned up. Exhaust measured 1.6" exact, intakes I am guessing are 2.08" since they made a 2.02, 2.055 and 2.08
#49
I got a good deal on a set of stockers with trunion upgrades so i am good that way.
#52
Just got my heads back from getting the valves freshened up.
Ferrea made the patriot valves and they can still be purchaed
I figured i would have my heads flowed while I am furhter disecting this engine because i really hate not knowing what I have.
Turns out these are some pretty good heads. D&E casting the machinist is certain they are 243s. Cumbustion Chamber measured to be a hair shy of 60cc. they flowed extremely well for cathedral port heads.
#54
With the help of the for sale section I picked up some new head studs and am ready to get the top end back together.
I also found out what cam the engine is running.
it is an SLP #51013 243/228 .576/.571 113 LSA
#56
This is an ok cam for now since i am going to run a 200 shot this year and go for a turbo next year if things don't make me happy with the nitrous
