mpg is bad !!!! on cammed ls1 need help !!
my car is getting really terrible mpg i have a automatic 3600 stall torquer v2 cam and 373 gears my injectors are making a pissing sound when it hits 3rd or 4th and when i go in reverse my car has trouble idling should a dyno tune fix all that or should i go with a smaller cam and no stall ??? need help plzzzz!!!!!!!
IMO, if it's in the tune then your tuner should be able to fix it, or at least let you know what's possibly at fault.
LS1Tech Premium Sponsor
A good tune should fix most of your issues, other than the MPG (due to camshaft and converter). However, if your tune is way off, you may see a little better MPGs with a better tune as well.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
yes it has been tuned i had it tuned by texas-speed and the car worked perfect but when i moved down south i put the stall and gears and tuned by excessive motorsports it has been acting up bad when i put it in reverse the car has trouble idling and sometimes turns off and when i stop at a stop light the car jerks shifting to 1st and then has trouble idling and also everytime i put gas and i took the car back plenty of times and all they say is there is really nothing else they can do and i dont want to spend even more money to have another person tune it should i just go with a smaller cam like the tsp 220/220 and no stall cuz the power band starts at 1200 ????
i have went back and told them that but they just keep saying nothing is wrong with it and we cant do anything else and now they say the dyno tune might help with all the problems i am having but i dont want to waist money to find out it acts the same way if not worse
I have a 3600 stall with a stage 2 shift kit it takes a while to get used to sometimes when i back up too slow and im cutting the corner sharp my car dies on me now with a cam i can see the problem happening more often. Like everyone said tho you do need to go to a different tuner one that either your friends go too or one that everyone and their dog goes to. tell the tuner what the deal is and see if he can take a look at it also if the tuner recommends a new tune then talk to your old tuner and make him pay for it since he didn't do his job right!
dumb couple of questions...
you check fuel pressure at rail?
you check your plugs and compression?
also may want to remove injectors and reverse flush them. replace o-rings, dont re-use.
I am thinking the tuner knows what is wrong but does not want to fix your motor.
yea ill try all that and yess he dosent really care at all about my car since i dont know him nore anyone at the shop and also thats what im worried about cuz my trans dosent feel like its shifting right anymore and it jerks alot shifting to 1st and it makes a loud rubbing poping noise when i dont completely stop and get off the brakes i think i should just change to an m6 lmao
