What is the usual YEARS/MILES to change PCV?
Have a 1999 and has 168K miles and the original owner never changed it and I don't have any oil consumption which I heard was common due from the PCV. Should I change it? I also heard they changed the design. Is the part in the rubber hose?
Pcv refers to the entire system of positive crankcase ventillation. It probably consists of multiple hoses/tubes, and plastic fittings, and of course the pcv valve which is simply a check valve.
Since those things are cheap to replace it should be done and maintained well. If one of the tubes collapses or gets clogged it can damage an oil seal inside the engine permanently or cause a bunch of oil to get sucked into the intake manifold. If I was you I would learn which hose was my "fresh air inlet tube" and keep an eye on it regularly.
Lol silly boy
OP, unfortunately you can only replace the little valve on the rubber line for about $2. The rest of the system isnt serviceable, its just a few hoses. The problem is they get very brittle and rot apart. If this happens you have two options, configure a new setup with hoses and Y fittings yourself out of other materials, or two cap the valve cover vents and PCV valve and move to a newer system that vents from under the intake. This requires intake removal and the purchase of an "ls6 valley cover". It has a built in orifice making a PCV valve obsolete and cleans up the engine bay some. Search around you'll find lots of info on it.
first, the LS6 valley cover does not have a check valve inside it, it has nothing to do with pcv valve action, and it doesn't make the pcv valve obsolete. That is a myth I am not sure where it started but I am crushing it because I have inspected and had this discussion already.
The second myth is that it cleans up the engine bay. All the LS6 cover does is ADD another port to the crankcase. That sounds like the opposite effect to me, more complicated engine bay.
God damn youre stupid. Orifice is a metered device, NOT a check valve. And yes it does have one. Using an orifice means it does not require an actual check valve.
Also, eliminating two, foot+ long hoses in favor of one thats 4 inches cleans up the engine bay quite a bit. Now go sit in your corner for the rest of the day little boy.
And now everybody can see your words and how stupid you look, time and time again trying to call me out when it is yourself who is blind.
Post 38 of I purchase and investigate the use of the famous LS-6 valley cover. I, like so many, had heard it was an "upgrade" of sorts, so I wanted to see what this was all about.
At first glance, it appeared to be a very well baffled check valve as everyone suggested.
However, upon testing, it turned out to be only a simple baffle with no check action.
https://ls1tech.com/forums/generatio...l#post19526698
Useless, another hole in the engine? No thanks. I went back to the original truck valley cover.
https://ls1tech.com/forums/generatio...l#post19567639
Post 38
I later had discussions with another member about this exact issue, and we determined the same thing. 2x.
There's really no need to debate here. They're both effective means to vent a crank case.
The only place I'd see a real need for check valve with the LS6 setup is on the fresh air inlet so nothing gets pushed up to the throttle body.
As far as servicing an aging and brittle PCV system, replacing the hoses is advisable if they are dry rotted and cracking.
I think you need some help with terms. An Orifice is not a check valve. You seem to think it is. The LS6 cover does not have an check valve. It does not have an PCV valve. It is just a hole with a baffle. lrn2engineer
LS1Tech Administrator
Received 1,726 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I wonder if Dorman also has an aftermarket version? I know they do for some makes/models, but I haven't researched this one specifically.
