Rough idle + misfire at idle after plugs
2000 ws6 m6 here, just went from my 25k mile TR55 copper plugs (.050 gap) to TR5 iridium (.038 gap) since allegedly GM put out a bulletin calling for these. They're NGK though, not GM. I now have a rough idle even when warm and misfire under load when cold for only a minute or 2. I have a small (?) exhaust leak from my headers at the y pipe, could the new plugs somehow be more sensitive to an off AF ratio? Checked narrowband O2 voltage and one side is consistently around .450-.550 and the other jumps anywhere from .015-.950. Any help is appreciated.
im thinking you pulled a plug wire or cracked a porcelin by accident.
The following 2 users liked this post by Kjduvall:
Jake Wade (01-18-2024), wannafbody (12-05-2023)
LS1Tech Administrator
Received 1,685 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
FWIW, on my '02 Z28 I went from factory platinum tipped plugs gapped at .060" to the (then) GM updated/recommended service replacement iridium plug gapped at .040" and didn't have any issues at all.
You're likely correct, forgot to add I actually had to replace a wire afterwards because I literally ripped the innards out of one due to how stuck it was on the plug...probably didn't do any favors to the others either.
Update: Installed new wires and now it runs fine. Not sure if any were damaged or if one or two weren't seated all the way. The driver side rear wire was suspiciously easy to pull off. Thanks fellas
The following 3 users liked this post by greaseman69:
Okay- pulled all plugs and wires. Closely inspected every plug, no cracks in the porcelain. Two of them on the driver side had oil on the threads, probably valve cover gasket? The problem still exists, unfortunately no code so I don't have much to go off of. Check oxygen sensors next?
Still, possible that you have a defective spark plug, or wire.
I'll check for vacuum leaks. I forgot to mention I had a Frost tune done a few years ago (LTs, air lid, egr and air pump delete) would a tune for TR55s have any issues with these plugs?
Arrgh I'm losing my mind a little bit. Went and dropped 40 bucks on a set of TR55s just to see what would happen since those were in it before and it feels exactly the same. My new plug wires may even be a little wonky now since I've taken them off a few times already. Didn't see any possible vacuum leaks but I haven't smoke tested. What vacuum lines are even around the plugs? PCV is there but thats all I could think of bumping. Gonna be pissed if it does end up being a total coincidence like a coil pack
Also, good news, slapped some dialectric grease on the plugs and it definitely runs better. Still just a LITTLE hesitation when cold and the idle isn't perfect, but 80% better. Must still be the connection on one or two wires. Third plug wire back on the passenger side could be wiggled more easily than the others. Gonna try to swap an old wire and see if it stays tight. These are MSD by the way, never had any issues the first time I did plugs.
Dropped even more money on a second set of msd wires and same issue. Made positively sure they're on tight...two clicks on the coil and one on the plug every wire. One of the wires was fault and wouldn't click at all onto the coil so I have one older wire but I left it on a plug I was 90% sure was tight. Same issue!!! Pulling my hair out. Unless it's that last plug. Gonna switch another older good condition wire with that and see how it goes. Other than that, I don't have a clue. 2 sets of new plugs and 2 sets of new wires. Are there scan tools out there that will detect misfires on specific cylinders even without a code? If i know what cylinders are the issue I'll be golden.
Getting back to basics here; did this issue ever exist before you did the plug swap? You mentioned something about an exhaust leak at the header - if it's near an O2 sensor then I would probably fix this before digging any deeper with cylinder specific diagnosis. It does seem coincidental, but maybe this problem just happened to get worse during the plug swap (maybe something was touched/shifted/bumped that worsened the leak)?
My old AutoTap scanner will show cylinder specific misfire data like you're asking for, but this is an ancient program running on my 1997 IBM laptop with Windows 95, and it requires a serial port connection for the cable. I'm sure there are modern tuning suites that will give this same data.
removed one while it was running before (cold)
and there wasn’t even a stumble.
It's best to get answers to all of these questions before dismissing the possibility, especially since the OP has had no luck fixing this thus far.
I'll give this a try, already popped the hood in the dark a while ago and couldn't see anything but that might do it.
But how are we defining "cold"? Is the OP certain that the issue occurs even when the engine is in (confirmed) open loop? Or are we just assuming 'cold' based on run time? OL will not last nearly as long if the engine had been run semi-previously (vs. true overnight cold start). Also, if the car has headers (which was mentioned early on) then it's likely been tuned at some point. Has CL (closed loop) enable temp been changed in the tune?
The following users liked this post:
Y2K_Frenzy (01-12-2024)
