IS 85w/140 okay?
Originally Posted by BLKWS.6
Is 85W/140 Royal Purple okay for my 2001 WS.6 rear end? I put it in and am wondering if this is okay (I know...backwards
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Easy. Pop the rear cover off, drain it (I spray it out with brake parts cleaner as well), clean the cover and mounting surfaces, then put a bead of RTV around the cover and snug it back down. Then remove the pipe plug on the side of the diff case and refill it with fluid until it's level with the hole. Reinstall the pipe plug and you're done.
How often should the fluid be changed? I may consider changing it some weekend this winter... and what about changing the gear oil in the T56? How simple is it and should I do it? I'd like to switch to Redline.
I changed the tranny fluid in the 4T60-e in my '92 Z34 but that was an auto so I know how to do that. Never changed fluid in a manual.
Even simpler than an auto... I love it.
What's the best way to fill it back up? I can't see a funnel working too well under the car. I'm wondering the same thing about the diff. too. I can't see how easy it would be to fill either.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
the first three times i did my clutch swap, i pulled the center console (not very hard at all) and used a funnel with a hose attached run in the fill port of the tranny. now (read: the last two times i did my clutch swap), i just pull the shifter, and fill it thru there. i use synthetic tranny fluid, i cant remember which brand and im too drunk to get off my lazy *** to go to the garage to find out. if i find this thread tommorrow, ill post the brand...
(ps - i did the clutch swap five times due to parts failing because centerforce daul friction clutches are SHITTY, SHITTY, SHITTY, SHITTY, SHITTY, SHITTY, SHITTY, SHITTY, SHITTY, SHITTY clutches, not my fault on the intalls. just thought i should clarify since im drunk, and im probably not making sense...)
(pss - dont EVAR run centerforce dual friction clutches in an LS1/T56 combo. they SUCK!!!!!!!!!!!
-cam
-cam
