General LSX Automobile Discussion Non-technical LSX related topics.
Running rubbing alcohol to pass smog
Old 02-13-2007, 10:16 PM
NoGamesLS1's Avatar
Default Running rubbing alcohol to pass smog
Somebody told me that you could run rubbing alcohol and pass smog. Will this work or will it srew up my injectors/motor?
Old 02-13-2007, 10:18 PM
Magnet's Avatar
never heard of this?
Old 02-13-2007, 10:19 PM
Revelation Z28's Avatar
seafoam it. dont attempt anything that hasnt been proven.
Old 02-13-2007, 10:32 PM
blackSS01DP's Avatar
I wouldn't try it. Never heard of it.
Old 02-13-2007, 11:00 PM
Starz T/A 17's Avatar
I have, worked at an auto parts store for 3 years, dont put rubbing alcohol in your car, go buy the alcohol that you add to your gas tank to keep your lines from freezing in the winter, b/c alcohol burns cleaner then gas it will help some
Old 02-13-2007, 11:05 PM
I just remembered the name of it, heet and iso-heet the iso heet is stronger
Old 02-13-2007, 11:06 PM
BLKWS.6's Avatar
Retard your timing as much as possible, induce a few VERY slight exhaust leaks by loosening the clamps, run the alcohol that Starz recommended, and make sure the car is as hot as safely possible.
This is the formula with which you would most likely pass. Is it good for the car? HELL NO! If you blow it up will I claim responsibility...HELL NO! Would I recommend just tipping them instead of jacking with your setup...
Old 02-13-2007, 11:07 PM
98TADRIVER's Avatar
how about some moonshine?
Old 02-13-2007, 11:21 PM
BLKWS.6's Avatar
You would have an easier time passing using $20's.
Old 02-14-2007, 12:07 AM
NoGamesLS1's Avatar
Thats what I figured. I didnt think it would be good on the injectors or any other part of the motor for than matter. I was just asking because the crooked smogman has become few and far between
Old 02-14-2007, 12:15 AM
If you loosen your exhaust then you will fail for an exhuast leak, Its happened to me, but with the heet its meant to be run through your fuel lines, just dont run too much put like 1-2 bottles in with a full tank and you should be good
Old 02-14-2007, 12:19 AM
NoGamesLS1's Avatar
Any way a bottle or two of that "guaranteed to pass smog" formula will help a 43x* cam with no cats
Old 02-14-2007, 01:33 AM
chec_o's Avatar
your in california just look for one of those mexican repair shops, learn some spanish and get your inspeciton sticker w/o doing anything to your car just slip the guy a few bucks and a taco you'll be fine.
( for the record I am of mexican decent so the above comments are not racist they are just an observation of my own people)
Old 02-14-2007, 01:59 AM
LMFAO!!! thats the way to do it
Old 02-14-2007, 02:33 AM
NoGamesLS1's Avatar
I suppose that is an option...got someone in mind?
Old 02-14-2007, 06:43 AM
Genesis_26317's Avatar
Old 02-14-2007, 12:07 PM
99Z28LS1's Avatar
on the car or the driver
im curious as to what you "could" use instead of regular fuel. i know for a while i was paying under the table for the sticker
Old 02-14-2007, 01:03 PM
MSDRbooger's Avatar
why not just run cats? today's high-flow converters aren't that restrictive AND you'll pass emissions
Old 02-14-2007, 01:22 PM
NoGamesLS1's Avatar
I dont think you could get a 24x* cam to pass smog with cats, unless you have several set of them
Old 02-14-2007, 05:19 PM
Yeah just stick another two or three on the back over there, hell go with a six pack!!!
Damn you bastards. Do you know what it is like trying to pass inspections in Austin Texas?
"Hey can I slip you a ten to pass me?"
"No but you can give me that ten to stop me from having my manager call the cops on you for bribery."
Quick Reply: Running rubbing alcohol to pass smog
