K&N vs. SLP I need advice
My car is stock right now and i want it to breath a little better so should i go with the Cold-Air "FlowPac" from SLP or should i go with the K&N or mososso setup. Any advice helps K&N claims 15 horsepower while SLP claims up to 20 horsepower. I also need it to be C.A.R.B. certafied because i am from California i dont know if the SLP kit is CARB certafied.
Originally Posted by kyle91z28
I say neither and just buy a new lid..
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
Originally Posted by BriancWS6
I agree with the others, just get a lid. There's nothing wrong with the re-useable gauze type filters though, I personally run a Holley Powershot and like it.
Originally Posted by taintedmeat
There's nothing wrong with them, other than inferior filtration when compared to a paper filter, and their inflated cost. They also arguably have the potential to foul your maf readings a bit if some of the oil they require to filter anything but the largest of particles happens to get stuck on your maf wires. Not worth it if you ask me, but if you already have one then cool. You will also not gain any power by using one, which is why a majority of people purchase them to begin with.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
In my experience using them, I haven't had a single problem. The people that do, are over oiling them, that's not the filters fault. If maintained properly, the filtering is sufficient enough. My intake tract is always free of dust and debris.
To each his own
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Wow, you sure are a hater of gauze type filters
To each his own![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
To each his own
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
i will 2nd what everyone else said.. buy a LID ... any lid. slp, whisper, MTI, there all the same. keep your paper filter from the factory, if you wanna go futher get the SSRA or FTRA (super sucker ram air, Fast toys ram air) they pull cool air up from below the car, and work great with a lid.
