Thnking about dropping the motor.... what do you guys think?
This winter I'm doing heads, cam and stall. And I'm thinking about dropping the motor/trans out the bottom of the car and here's why:
1. The heads/cam setup I'm going with is going to require flycutting. This should be loads easier out of the car.
2. It's a '98 and I would like to change the rod bolts and with the engine out this would be cake.
3. Torque converter would be very easy with the car out as well.
What do you guys think?
Good luck.
I got a question. Since you are going to go through the trouble of taking the engine out. Why not rebuild it? Another $1000 for some scat rods and mahle pistons and you have a brand new motor that isn't using stock ish and you don't have to get the pistons flycut. You'll probably make .5 more compression and have more piston to valve clearance. Meanwhile taking a small amount of weight out and increasing strength. Seems like the logical choice to me. Just my .02
This is a pretty good question. I don't know. I just never thought about it. I suppose that I could.
And from everything that i've read pulling the motor out the bottom is actually really easy. Even without having a lift. I'm a little confused
I don't really have the funds to rebuild the motor right now to answer your other question. And i'm pretty sure the stock bottom end can handle quite a bit. The only thing that would really need replacing is going to be the rod bolts. I wonder if I should change the bearings while I'm in there?
My biggest reasoning behind it is this: I could probably get heads, cam, torque converter, rod bolts and flycutting all done one hell of alot quicker than if it was all in the car and for what seems to be alot less hassle.
My biggest concern about pulling the motor is getting it back in the car. Putting **** back together always seems more difficult that taking it apart lol. How hard is it going to be to get it back in?
Thanks!
Look at it this way. With two floor jacks it take about as long to drop out the engine as it will take to pull the trans. With the entire engine out the time to swap the converter is about 20 minutes. Having the engine out will also save you several hours in swaping the heads due to no clearance issues getting to things. If your changing the cam you also won't have to pull the radiator and A/C condenser.
I'm doing the same thing this wonter because I'm changing heads, clutch, and headers.
PULL THE ENGINE
Re'
PULL THE ENGINE
Re'
PULL THE ENGINE
Re'
PULL THE ENGINE
Re'
Thanks man, this is exactly what I was thinking. I'll pull it.
