Longtubes, Cutout & Stock Cam?
Tech Resident
What catback do you have on now? Cutouts aren't 100%. Even when your cutout is open, a significant portion of exhaust gas is still going to pass through your muffler. At WOT, exhaust gases move fastest, so that means more and more gas is going to bypass the cutout and go through the muffler.
When I'm at idle with the cutout open, my car sounds mostly like my catback. If I stand behind it, almost all the sound comes out the tips and very little out of the cutout.
When I cruise around normally driving (under 3000 rpms), it sounds mostly like the cutout - raw and like pure ****, almost toneless. Just...weird. Very little exhaust goes through the muffler and mostly out of the cutout.
At WOT, it sounds badass because it mostly sounds like the Corsa. The higher in the RPM range I go, the more and more it sounds like the catback because the exhaust travels faster and faster and it mostly winds up going through the muffler.
So, what catback are you running? If you're running a stock catback, it's going to sound a whole lot different than my Corsa with an open cutout. If you have GMMG, Magnaflow, Hooker, whatever...it's going to sound a good bit different than my Corsa with an open cutout.
I have Magnaflow 59959 cats, so it's as close as you can get to running no cats as possible without physically removing them. They do almost nothing to exhaust sound. They don't really change the tone and have little to no effect on volume, so my car sounds like it has no cats.
Cold start:
Warm start:
Cold start:
Warm start:
http://s268.photobucket.com/albums/j...empeg_0001.flv
longtubes through a y-pipe only, it is cammed though.
long tubes wont sound much better. here is a clip from my car
http://myspacetv.com/index.cfm?fusea...ideoid=7388825
I don't have any clips from before I had a cam but when I had dual cutouts right after the headers it sounded ridiculous. It got even louder once it was cammed but it still shook the ground. This was with a quiet SLP dual/dual exhaust so don't worry about the catback reducing the sound at all.
LOL just a couple points I need to make.
1. dont be mad at me because I dont have to have/pass inspections.
2. if you think a unrestricted,cammed ls1 sounds like ***, well you sir are a pillow biter.
Lastly, if u lined up against me, thats all you would see is ***......
Completely wrong. At WoT almost none of the tone is coming out of the catback. That's why it STILL sounds raspy, toneless, loud and like crap. I don't know why you think this sounds "good". If you truly hear sound out of your catback you either had a horrid cutout install or your nuts.
Exhaust speed has nothing to do with how much gas is coming out of your tips. Gas flows through the path of least resistance. More gas is going to come out of your cutout percentage wise the closer you get to WoT. Once the catback becomes a higher pressure zone, everything else goes out the cutout.
yup
yup
Agreed with all above.
Tech Resident
yup
yup
Where are you getting this from? Any of these tests can be performed with a high pressure water hose. Take a straight piece of exhaust tube and put the cutout open on the bottom. Turn the hose on low. Most of the water is going to fall out of the cutout. Turn the hose on high pressure. Most of the water is going to go right over the cutout and out the back of the exhaust.
Exhaust gas is no different. You're the one that is completely wrong.
Not to mention the main focus here is sound waves, not exhaust gas itself.
There is way more exhaust tone at WOT then there is at half throttle. WOT sounds mostly like my muffler, half throttle sounds like...well, nothing. Just raw noise.
Trunion King
What is that supposed to mean? Are you trying to tell me 100% of the exhaust gas goes out the cutout? You're completely, completely, completely wrong. You're not even close. This isn't a perfectly theoretical world, you know. Any of the things I've just said can be easily verified with a simple garden hose. It's fluid mechanics.
by C.J. Baker
