who uses mobile1 M1-206 oil filters instead of the M1-107?
just wondering who runs them instead of the M1-107's. they are the same price, and allows for 6qrts of oil instead of the 5.5qrts stock, and they have more filter surface area
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Is this the longer filter then the shorter Mobil 1? I heard that was bad because of the potential of it getting sheared by road debris.
The m1 107 comes even with your oil pan at least.
Thats what I ran on my T/A. It gave me a little piece of mind, I do not know if it helped any other way. I always ran six with the short filter anyway. I have not had the Z06 long enough to change the oil in it yet so I do not now how much clearance there is for it on here. We will see....
I run the long filter, M1 or K&N, with 6 qts, have so for years, never found even a scratch on one. The filters on these engines are teeny compared to SBCs, figure the extra filter area can't hurt.
I use the long one, my header is closer to the ground and right next to it. IMO it's worse to bang a header than an oil filter, and I check under there right away if I ever hit anything. Rather see a beat up oil filter than a crushed header tube.
LS1Tech Administrator
Received 1,723 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I use the M1 107 filter, and 5.75 quarts of oil. I doubt there's any significant benefit in running the longer filter.
