hypertech V Hptuners
http://www.hptuners.com/products/vcmsuite.php
http://www.hypertech.com/hyperpac/index.php
so i cant decide between these two products. i am looking for the best MPGs but more power is always a plus. i have a 99 z28 camaro. i currently have a hypertech tuner but I'm looking for something with live data read outs like these. i like how the hyperpac can be mounted on my dash and used every time i drive as the hptuner has to be run through a laptop. but I'm thinking the hypertech tune is not going to get as much mpg as the custom tune of the hptuner will get. i am also worried that the hptunner will be hard to work as i really have no clue on how to tune a car. i have a k&n air charger and flomaster exhaust and i don't think the hyperpac will custmize to the better flow as the hptuner would. so do you think i will be able to get enough mpg out of the hptuner to make it be worth how hard it is to use??? any info on ether is well appreciated!!!
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
hp tuners can b very hard to use if u have nvr tuned a car b4, i whouldnt go messing around with it unless u know wht u are doin, cause u can really screw stuff up on ur car
I would definitly go with Hp Tuners. The tuning can be tricky at first but trust me, if you put some effort into it you will get it. Also I picked up about 2 mpgs with a tune I made myself.
sorry for the question but will the hp tuner also be able to get rid of the o2 sensor codes? im pretty confused when it comes to tuners and what they can and can not do. thanks!
edit: when i get my cam later on along with LT's and intake can i use the hp tuner to adjust for these items?
Yes, HPtuners can get rid of the o2 sensor codes or any other error for that matter. It will work great with lts, cam, and intake, hypertech cant tune for any of that.
hp tuners hands down, but you gotta put some time into it - read everything you can find especially the hp tuners forum........ ive had it for 5 months and starting to feel like ive got a clue with it but still much more to learn
As for ease of use - there are a ton of tables in there and you gotta really take your time learning before jumping in and making changes, scanner is great through - got mine permanently installed on my carputer, always on(when car is running) and logging
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
