has anyone seen these LSx 32valve heads yet?
http://www.araoengineering.com/LSX.htm
what do you think about them? and have you seen them yet? do you believe the science behind it?
they can also be made to use all 6 bolt per cylinder with the LSx block
well they would work on a ls2 or anything of that bore or bigger i guess not just a lsx block. but ya i couldnt spend the money on those things unless i was in a n/a competition or something
those have been widely discussed here there was a guy in the LT1 forum that has been trying to get them to work for probably over a year now with little support and lack of communication from the company...
Holy **** *****.
405 cfm @.600 lift...very nice, to bad I have an LS1 3.900 bore.
They are rather pricey. I would pay around 4000 bucks max for a set of heads. Might as well just build a motor for that price.
I dont know how they share one rocker per two valves, thats what stumps me.
i would like to see the flow #s from .050-.400. should outflow a 405cfm 2 valve head by a ton down in the lower lift ranges. i find thier claim that they work with standard pistons to be comical though
i think the price is actually pretty good, assuming the rocker setup is stable at 9000+rpm (which it probably isnt)
you are missing the whole point of running a 4 valve head. they will KILL the All Pro or any other comparatively flowing 2 valve head in the lower lift ranges. also the smaller, lighter valves are much easier to control at high RPM
There was a huge thread going in the advanced section. https://ls1tech.com/forums/advanced-engineering-tech/694109-arao-32-valve-heads.html
