Need help on a 96 V6 Firebird
The car ideals fine but when you step on the throttle as it gets to pulling RPM's around 3500 or above it feels like it is being held back and a slight vibration (kind of feels like spuddering).
I am going to change the fuel filter on it tonight.
Does this car have a MAF sensor?? If so where is it located?
Any other thoughts??????????
As for the plugs, I changed most of them from the bottom.
hope this helps.
I am going to take the cat off to see if that changes anything next, if not then I guess I will change the plugs and wires.
What is the best way to route the wires if I put new ones on them?
This thing is a real headache
I had the Cat removed and that helped a lot, it was almost totatly plugged up, I changed the fuel filter, new plugs, new wires and made sure my fuel pump was at the correct pressure. Now the thing runs worse than it did to begin with.
my bro did that on his truck and didn't realize it at first.Don't sink it in a pond... I'll take it if you hate it that much
Does anyone have a diagram for which plug goes to which coil so I can double check to make sure I don't have them mixed up??
While working on the car I was under the car replacing the plugs and routing the wires while my wife was taking each wire off to replace, not sure if they might have gotten mismatched.
Does anyone happen to have some good used coil packs for one of these?? Some that they know are in good working order?
I *think* you can get the coils tested at autozone, but not sure on that. I've not done it, I just heard it somewhere.
I gave up this morning and took it to a mechanic to check the codes. I pray he can find out what it wrong and it dosen't cost me an arm and a leg.
I would try to rule out spark and fuel starting with the easiest things first and working up. I doubt it is something other than one of those. Did you get an SES light?
Good luck.
