heater motor question?
I have a 2001 gmc sonoma and the heater recently stopped blowing out heat. All 4 of the speed settings don't work. They were working fine one day and then the next time I turned my truck on they wouldn't work. Does anyone know if this is from the heater motor going bad, or just a resistor or something?
Thanks a bunch
Britney
Unless there's something unique about a 2001 Sonoma, there's no such thing as a heater motor. Its just a fan, which blows either cold or hot air out the vents. Sounds like your fan just took a poop.
Could also just be a fuse that popped, so check it.
www.rockauto.com
ACDELCO Part # 1581128
This is for both the 2.2 and the 4.3 engines, same blower motor. $91.00 Usually this place has great prices.
I checked my HVAC fuses and they looked good. I decided to then see even if the AC worked in it and when I switched it over to AC the fan came on!!! But there seems to be another problem.....I have fan settings 1 - 4 and 4 is now off, but is supposed to be high. Anyone have an idea why the settings would mix up?
Thanks again
Britney
Maybe the Sonoma is different.
Might have better luck here:
http://www.gmcforums.com/phpBB3/
