Sponsored by: CARiD
Another thermostat question
Old Feb 13, 2009 | 09:46 AM
blackodium's Avatar
Red face Another thermostat question
1 What thermostat do factory 98-02 TA's have?
2. If i wanted to install a 180 stat do i need to reprogram the computer?
Please help.
Old Feb 13, 2009 | 10:26 AM
2001NBMZ28's Avatar
My owners manual says 180 - it was stamped 86C inside.
Old Feb 13, 2009 | 10:27 AM
NOBR8KSS's Avatar
I think the stock thermostat is 180-195. You shouldn't need to change out the thermostat for a colder one, but if you want to, you can. You don't "need" to reprogram the PCM, but the fan settings are based on the stock thermostat.
Old Feb 13, 2009 | 03:10 PM
LS6427's Avatar
Please help.
T-stat has nothing to do with the PCM, if its a 180*, it will open at 180* and start the coolant trade between the engine and radiator, and cooler coolant will flow into the engine and the hot coolant from the engine will flow into the radiator. Nothing needs to be done with the PCM unless you want your fans to come on at a different temp.
Old Feb 13, 2009 | 04:13 PM
nemss1's Avatar
no need to adjust PCM for a cooler stat but u will benifit by tuning your fans to come on sooner
Old Feb 13, 2009 | 04:28 PM
blackodium's Avatar
ok so u dont need to tune it for a 180 stat?
Old Feb 13, 2009 | 04:43 PM
LS6427's Avatar
Uh.....no.
Old Feb 13, 2009 | 05:30 PM
blackodium's Avatar
sorry not tune but reprogram the fans
Old Feb 13, 2009 | 06:13 PM
LS6427's Avatar
Alright, look pal, NO PCM dyno tune needed AND NO resetting of the fans are necassary. If you want to you could reset the fans to come on at a lower temp than stock, but if you do I would put a 160* t-stat in, otherwise just leave the fans alone and let the 180* t-stat do the work.
j/k Do just the t-stat and you're good to go.
Any more ******* questions..... j/k again lol I'm on a roll.
Old Feb 13, 2009 | 06:22 PM
blackodium's Avatar
gee thanks man. o you misspellled necassary.. hehehehehe
Old Feb 13, 2009 | 07:09 PM
jimmyblue's Avatar
Moderator
The stock 'stat is the same as the "180" you'd buy,
changing it out for any reason besides failure or
insane boost / compression ratio is a mistake.
All you need is decent fan settings, and to clean
the radiator and condenser of debris every so
often (airflow is -the- problem). You will gain
nothing from cooler water, even if the 'stat would
give it to you when you really needed it. But a
hot radiator has no cool to give, and a system
where the thermostat is not in control is too
variable to tune well or get consistent performance.
Old Feb 13, 2009 | 07:19 PM
therealcreeper's Avatar
my thermostat died yesterday. replacing it with a stock one tomorrow. i don't trust all the 160 degree hype.
Old Feb 17, 2009 | 04:25 AM
tording99Z28's Avatar
I changed to a 160 thermostat and used HPtuners to change my fan settings. Prior to this my car saw temps of 220+ after a hard WOT pass, now it never breaks 185 and most of the time is between 175 and 178 or so. Which do you think your aluminum block and heads enjoy more, 180 degrees or 220+ degrees?
Old Feb 17, 2009 | 04:53 AM
myk's Avatar
myk
I tried asking my car but it didn't say anything back to me...
Old Feb 17, 2009 | 12:06 PM
LS6427's Avatar
Same for me with my 427ci...it runs so friggin cool ALL the time. 185 is the norm even with aggressive driving. Even with A/C blasting in the 90* summer in traffic, it never breaks the 215 mark.
But like "jimmyblue" said....the key with F-Body's is to keep the condensor clean. I do it as general maintenance every couple years and its friggin dirty as hell with debris each time. It doesn't only keep the A/C system running at its peak (coolness) but it will in turn keep the radiator getting its required amount of airflow.
Old Feb 18, 2009 | 02:18 PM
NOBR8KSS's Avatar
Engines aren't intended to run cool...neither for emissions or power reasons. Ideally you would want the cylinder head as hot as possible and the intake charge as cold as possible for optimum combustion. Hot cylinder head aids in combustion (you want to avoid it being so hot that you get preignition or knock)...cold intake charge is more dense and makes more power.
Ignore the hype...there's no need to lower the thermostat opening temp. Not that you would hurt anything with a cooler thermostat...you just won't see any benefit.
As others have said...if you are overheating, it's more likely a problem with airflow through the radiator, dying waterpump, or just a faulty thermostat.
Old Feb 18, 2009 | 03:50 PM
I don't fully agree with the above comment. There is a point yes that if the engine ran too cool it would not allow for proper combustion but we are talking the engine would have to be down in the 140's and 150's I bet. As long as you are hitting the 180 mark. The benefit may not be in the performance but it will be in the longevity of the motor. Aluminum likes to warp after being exposed to high temperatures. Heat is the number one killer of all mechanical components especially in an engine. If the motor is running cooler then that means the internal components are also seeing lower temperatures. Not to mention other things in the engine bay that surround the motor are seeing less ambient heat from the motor. While the gain may not be in performance I am still going to see there are quite a few benefits to running your engine at 180 degrees instead of 220 degrees.
Old Feb 18, 2009 | 04:10 PM
LS6427's Avatar
To add to this...when the temp of the coolant reads say 195, the engine itself and its metal parts are hotter due to heat soak, so even if coolant were to read down in the 140's, its still going to be just fine for combustion because the inside of the heads and the cylinder walls of the block are a helluvalot hotter than 140.
Also, even though its not good for springs and some other things, anyone who has started a cold engine and IMMEDIATELY pulled out and mashed the pedal to do a WOT run......it feels more powerful than after an engine gets to operating temp. So combustion is just fine when its 100 degrees.
