Sponsored by: CARiD
No abs or traction control!!!!
Old Feb 26, 2009 | 08:41 PM
Y2K_Z28's Avatar
Default No abs or traction control!!!!
I have a 2000 Z28. The car will at times display the ABS independent light, park brake light, and Traction control light on the dash. Ive been told that the ABS sensor on the rear end could be the cause... If there is anyone who has experienced this problem and has any feedback plz let me kno. thanx.
Old Feb 27, 2009 | 10:57 AM
f-bodyfanatic's Avatar
Mine is doing the same thing every once in a while. I've heard that its the wheel sensors that are either dirty or need replacing. I may be wrong but thats what I've heard as causing the problem
Old Feb 27, 2009 | 05:22 PM
nemss1's Avatar
try pulling all the sensors and cleaning them
Old Feb 28, 2009 | 04:43 PM
Y2K_Z28's Avatar
ya ive heard that too.. the sensors are clean cuz i just put a whole new rear end in it and replaced them.... thats y im thinkin abs sensor cuz w/o a signal from the abs the ecm will shut off the abs and the traction control.
Old Mar 6, 2009 | 05:45 PM
99TransAm345hp's Avatar
where are the sensors specifically...i need to clean mine too
Old Mar 6, 2009 | 06:44 PM
TheLS1Kid's Avatar
Scan the car for DTC's.
Even if it happens at times there should be a history code.
Do you have larger diameter tires in the rear? If so that will cause the brake, tcs, and ABS light to come on.
Old Mar 6, 2009 | 06:50 PM
255 50ZR 16's in rear
Old Mar 6, 2009 | 06:58 PM
TheLS1Kid's Avatar
Same in the front?
The location of the sensors will differ if you have a 3 channel or 4 channel setup.
Do you have traction control?
Old Mar 6, 2009 | 07:35 PM
nemss1's Avatar
4 channel-sensor behind each front hub and sensor behind each backing plate on the rearend
3 channel-sensor behind each front hub and sensor on top of the pumpkin on the rearend
Old Mar 6, 2009 | 07:54 PM
yes i have tcs, its a button behind the stick
Old Mar 7, 2009 | 02:59 PM
TheLS1Kid's Avatar
All of your sensors are right behind each wheel/hub assembly.
Old Mar 9, 2009 | 12:36 AM
ok. i see them...problem is getting to them...i need to jack the car up
Old Mar 9, 2009 | 12:44 AM
bboyferal's Avatar
The few times I have run slicks (26") on my red TA, that happens to my car at high speeds... Due to expansion...
Unless you've changed tire diameters, something is causing the sensors to register the discrepancy... They have to be either dirty or bad.
Old Mar 9, 2009 | 12:47 AM
fknsmshn's Avatar
Werd. If your runnin different diameters from front to back, that could be the cause. Otherwise its just the sensors.
Old Mar 9, 2009 | 03:50 AM
nemss1's Avatar
the ABS computer doesnt like seeing wheels spinning at diff speeds and throws the damn 'dummy' lights
Old Mar 9, 2009 | 10:20 AM
it started doing this after i got new tires
lol
Old Mar 9, 2009 | 11:15 AM
bboyferal's Avatar
lol
AHA!
